Power booster for 1976 comet
Discussion in 'New Members Forum' started by Habs26, Jul 17, 2020.
  1. Habs26
    Habs26 Member
    Kingston
    1976 Comet
    I have a 1976 Comet 4 speed manual with disk brakes front and back. I was wondering if it was possible to add a power brake booster to a manual transmission.
  2. mojo
    If you have room for booster and enough engine vaccum, shouldn't be a problem.
  3. Habs26
    Habs26 Member
    Kingston
    1976 Comet
    I heard that with manual transmission there may be not enough vacuum is there something I could add to ensure proper vacuum
  4. mojo
    Manual transmission has no bearing on vaccum; many cars w/ manuals have boosters. Vaccum is dictated for the most part on camshaft/engine timing. AFAIK.. Aftermarket vaccum boosters can be installed to increase vaccum. It's possible you have enough to operate vac system, unless you have big cam. I'm not sure what min. vac required to op. the system properly, but, I'm sure someone will chime w/ more knowledge than me. Also, info can most likely be sourced from some of the performance brake websites.
  5. Habs26
    Habs26 Member
    Kingston
    1976 Comet
    Thanks for the info.
  6. Habs26
    Habs26 Member
    Kingston
    1976 Comet
    Does anyone know what power booster would fit my 1976 comit
  7. mojo
  8. mojo
  9. Craig Selvey
    FYI: FACTORY power disc brake booster will not work on a manual transmission car. The clutch pedal rod is in the way.
    BBMS18 likes this.
  10. Habs26
    Habs26 Member
    Kingston
    1976 Comet
    Has anyone ever install the
    BS1011K - Dual Diaphragm Remote Brake Booster
    from Master Power Brakes
