Power steering cooler as an oil cooler?
Discussion in 'Technical' started by t.ramsey, Jan 4, 2011.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Another point to ponder...
    Water to oil cooling transfers far more heat, far quicker than air to oil.
    An air to oil cooler must have a much larger area to provide the same cooling.
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Good point!
    Big truck diesels are set up that way.
  3. injectedmav
    injectedmav Member
    Georgia
    I agree. As long as your cooling system is in good working condition, adding an oil cooler has little or no effect on the coolant temp. The Ford diesels we work on have oil coolers of the same stacked plate design in the belly of the engine and lowers the oil temp by at least 25-40 degrees F. The Cobras use them, all the diesels since the 94 DI (ford) use them, Police cars use them, just about anything with a towing package uses them... etc. If they didn't work, they wouldn't spend the money to up-fit them.
  4. Weichel91
    Weichel91 Member
    Lake city mn
    1972 maverick
    Ratio411- can I see a picture of your hose routing? I happen to have an 351w with the cooler and lower hose. If it fits well I may as well use it.
  5. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    This thread is from 2011 and the last time Ratio411 was on the forum was Sep 29, 2016.
  6. Weichel91
    Weichel91 Member
    Lake city mn
    1972 maverick
    I noticed he was gone after I posted. Oh well
    BBMS18 likes this.
