power steering delete
Discussion in 'Technical' started by tranzman, May 12, 2011.
  1. tranzman
    tranzman Member
    azusa ,ca
    69 1/2 maverick
    where did you get the adapter ?,all the ones i see are $160 +
  2. mav76302
    mav76302 Member
    Mesquite, Tx
    1976 Maverick Stallion
    I've ran into the problem of switching over of needing the center link, pitman arm,and idler cause it was different. no one could give me an answer to why the idler was different but it was.
  3. maverick75
    which tie rods did you use? If you swapped it from a non disc brake car then the issue would have been that. You'd need to run the tie rods that fit the disc brake car.
  4. mav76302
    mav76302 Member
    Mesquite, Tx
    factory disc on front; the problem came from the idler arm. the original had a stud at the end and a hole in the center link. the man center link had a stud instead of a hole. I called carquest and they had a idler for the car with a hole.:hmmm:
  5. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Can I reuse my power steering pitman arm with a manual center link? They both have the same part numbers.
  6. mercgt73
    Not if I remember correctly, the pitman arm bushing tapers are opposite. One attaches to the center link from the top, the other from the bottom. So you have to use a p/s pitman with a p/s center-link, and vice versa. Are you saying they have the same ford part numbers on them?
    http://1bad6t.com/Maverick/diagrams/untitled197.gif
    http://1bad6t.com/Maverick/diagrams/untitled198.gif
  7. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Yes they have the same part numbers.
  8. mercgt73
    What is the part # you have?
  9. mav76302
    mav76302 Member
    Mesquite, Tx
    I think mine was the same too not sure about part numbers but looks wise looked the same. I just used the new one to be sure.
  10. Mavman72
    Manual and Pwr steering pitman arms are different...As mentioned above as well as the ratio/sweep on the pwr strg pitman is different and will not work with a manual center link.
  11. rthomas771
    You're looking at the GROUP number. The part number starts with a letter
