power steering issue
Discussion in 'Technical' started by sam03rc, Dec 26, 2009.
  1. 71gold
    the difference is...one is tapered from the top...the other one tapered from the bottom...they are shaped the same...:tiphat:
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    cool i PM you comet 73 but i could use either one of his with my tie rods even if one is from the top or the bottom????
  3. 71gold
    My Bad...."the difference is...one is tapered from the top...the other one tapered from the bottom...they are shaped the same"...:tiphat:
    i am refering to the...pitman arms...:oops:
    i used my '73...tie rod ends and idler arm...:yup:
    ...:Handshake...
  4. sam03rc
    sam03rc Member
    gates county, nc
    ok i see that the pit arms are like that but which one do i need to use? or can i use both
  5. 71gold
    there is only one...it's on the steering box...:Handshake
  6. sam03rc
    sam03rc Member
    gates county, nc
    yea i know there is only one. but what im asking is can i use either one of them? like the one that tapered from the top and the one the tapered from the top? or can i only use one of them on my 72 since the other wouldnt work?
  7. 71gold
    you will have to use the one with the correct taper for the manual drag link...(taper from top)
    ...:bouncy:...
  8. sam03rc
    sam03rc Member
    gates county, nc
    ok thanks so i need the one tapered from the top to make it work with mine ill make sure he has that one thanks
  9. rthomas771
    Here's the power steering setup (the clean one)...and the manual steering (the dirty one).
    [​IMG] [​IMG]
  10. sam03rc
    sam03rc Member
    gates county, nc
    cool thanks yes im just going to go full manual ill keep the parts just in case one day i want to go back but ill safe some weight, open up the engine bay alittle with out the pump and get some horse power back too
