Power steering problems
Discussion in 'General Maverick/Comet' started by alaskamaverick, Aug 3, 2015.
  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    I'm having issues with my power steering, I've got the front on jack stands. I start the engine and barely turn the wheel to the left and it slams to the left. I have to really pull on the wheel to get it to turn to the right then it gradually goes, but no longer do I get it all the way to the right, it slams back to the left.
    I have looked at other post with similar issues, however no one ever says what they did to resolve the issue.
    As always, I thank you for your help
  2. 71gold
    have you had it apart?
  3. alaskamaverick
    Spokane, WA
    depemds on what you mean on "have you had it apart."
    I removed it from a 1974 Maverick, and installed it on the 70 Maverick...
    yes the system has been apart, not the components
  4. Krazy Comet
    Dismal Swamp
    are you positive the cylinder hosed aren't reversed???
  5. alaskamaverick
    Spokane, WA
    No I'm not, but the lines are not crossed
  6. alaskamaverick
    Spokane, WA
    Krazy Comet, I saw in a post you were going to use a vacuum pump to get the air out. Did you ever do that and did it work?
  7. Rasit
    Rasit Member
    SE Pennsylvania
    Good chance hoses are reversed. Usually if they are reversed the wheel will slam back and forth uncontrollably. Try switching them, start it up and be ready to shut it down. When the hoses are right, turning the full left to right a few times should work any trapped air out.
  8. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i did that on my build, and that was the problem and solution.
  9. Krazy Comet
    Dismal Swamp
    I read the service manual and nothing was said other than fill and cycle the steering a few times, then recheck level... So that's what I did and works fine... The way the lines connections are orientated it's easy to get them connected wrong and hookup looks fine...
  10. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    This happened to me once. Connected the lines and started it up. Thought everything was fine until I started to turn the wheel. It slammed to one side and stayed there. Turned out that I had the hoses reversed. I ended up havin gto have the steering rack rebuilt because it blew out the seals when I did that.
  11. alaskamaverick
    Spokane, WA
    OK, 4 guys that had the same problem. I will reverse the lines and see what happens. Does it matter which end I reverse/swap?
  12. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    When we say the lines are reversed, we mean you have the high pressure line routing to the low pressure side of the steering box. Just swap the lines at the steering box.
  13. Krazy Comet
    Dismal Swamp
    No I mean the lines to power cylinder are reversed, while it's possible, reversing the lines to valve from pump isn't likely(at least without cutting)
    Makes no difference which end is swapped at valve/cylinder...
    alaskamaverick likes this.
  14. alaskamaverick
    Spokane, WA
    I will get on it tonight guys, thanks for your help. I will let you know of the outcome.
  15. 71gold
    ...:huh:...
