Power Steering Pump
Discussion in 'Technical' started by Jett, May 31, 2017.
  1. Jett
    Jett Member
    Los Angeles
    1976 Mercury Comet L6 250 ci
    Hey Guys
    So after rebuilding the control valve and slave cylinder (or what ever it is called) now my Power Steering pump is starting to give, I changed the belt as it was slipping and it helped for about a week haha.
    Now I can def hear the pump struggling.
    Should I try a rebuild or replace it? Is it "easy" or does it require specific equipment and measurement tools?
    Thanks
  2. Krazy Comet
    When these pumps get worn/old they moan(it's a rotary, vane type pump)... If it isn't leaking there isn't much one can do at home, I've had the one apart now on my Fairlane and other than a couple O rings and gaskets that's all the rebuild kits include.. There are no instructions in the shop manuals to actually replace any internal parts, but a no pressure condition could be caused by blown internal O ring or gasket..
  3. mojo
    I had my Ford "Thompson" pump rebuilt about 6 yrs ago; it work fine but could never stop it from whining. I finally wound up going to completely different setup.
  4. Jett
    Jett Member
    Los Angeles
    Thanks for the heads up, replacing it it's gonna be then, hopefully that part is doable at home?
  5. Krazy Comet
    You'll have to remove pulley from original pump but usually a bolt & nut kit that works well enough is included... Also may have to swap your orig reservoir(can) as you may just get pump internals... There are videos on youtube that show how to remove/install can... When I mentioned swapping the reservoir on one of mine, I'd gotten a bunch of gloom & doom from my local "expert" but in reality it's fairly easy...
    Here's the videos I reccomend, shows how to disassemble the pump... No it's not a Maverick but a Ford pump is a Ford pump...
    https://www.youtube.com/results?search_query=autorestomod+power+steering+rebuild
    Jett likes this.
  6. Craig Selvey
    Rodes Restorations in Galion, Ohio can rebuild the pump. Fast service.....good price.
    Jett likes this.
  7. Jett
    Jett Member
    Los Angeles
    Hi guys! Finally had my power steering pump rebuilt and I am putting it back in, quick question, how do I know if my belt is too tight or too loose???
  8. mojo
  9. Jett
    Jett Member
    Los Angeles
    Thank you! Very instructive!
