Power steering to manual steering
Discussion in 'Technical' started by 1moregear, Jun 27, 2009.
  1. Krazy Comet
    Steering box is different, has solid shaft that's around 3ft long the steering wheel mounts on to, plus bolt pattern to frame rail is different... Tie rod pin size increased with true '70 models(in all Ford/Mercury models)... The center link is probably too long and some of the early stuff had 1" shaft on steering box to mount pittman arm(all later stuff after '67 is 1 1/8")...
  2. Mav06
    Mav06 Member
    El Paso
    1970 2Dr 200 c.i I6
    Damn I was really hoping I could use at least th pitman and center link...I didnt care too much for the steering box to be honest
  3. Krazy Comet
    Yeah never easy...
    You'd also have to consider idler arm configuration, there are three separate versions for Mav/Comet('70-'72, '73-'74 & '75-'77, the late arms are same as Granada), I don't think any are close enough to work for the other... Some have pin in ctr link, others have hole with bushing... Any year setup will work as long as you have matching components, I have a '77 P/S setup on mine...
  4. Modr1
    Modr1 Member
    Sterling colorado
    1974 comet 5.0 toploader
    I'm in the same boat but finding a manual pitman arm for a 1974 comet seems to be impossible. I found an entire front steering kit for 75-77. Would it work since its the entire kit or would I just need to get a different idler arm?
    I have a 1974 comet. Holley sniper fuel injection, MSD Ignition, hooked headers, 4 speed toploader, posi rear
    71gold and Krazy Comet like this.
  5. Krazy Comet
    I have all the steering parts from a '77 Maverick in my Comet, idler arm is specific to '75-'77 linkage.
    Should be easy to find, Granada used same one.
    CA189HJN likes this.
  6. 71gold
    :Welcome:...:Handshake:
  7. Craig Selvey
    If you get all the parts from a 1975-1977.....it will work.
  8. Modr1
    Modr1 Member
    Sterling colorado
    Thanks for the welcome and thank you for the help. I will post a link to where I am ordering the entire front end kit from
