power steering
Discussion in 'General Maverick/Comet' started by DonnyG123, Oct 26, 2016.
  1. DonnyG123
    DonnyG123 Member
    Westchester County, NY
    1974 Ford Maverick
    i have a 1974 ford maverick without any power steering would i be able to take the power steering setup from a earlier model and attach it. any help would be great. thanks
  2. 71gold
    yes, but a lot of work. I would suggest a parts car to get all the parts and pieces.
    myself and others removed the PS and went to manual...:yup:
  3. Krazy Comet
    And some of us are happy retaining the P/S...
  4. 71gold
    he's not "retaining"
  5. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
    well im buying a parts car this weekend going to be using what i can then just sell the car
  6. Krazy Comet
    No kiddin'..
    As long as both cars have same engine you should have everything you'll need... If engines are different you will at least need mounting brackets, pulleys and pump, plus probably hoses... Steering linkage will transferable as unit, though vary somewhat by year... Basically breaks down to '70-72, '73-'74 & '75-'77... The later linkage is easier to find replacement parts as except for center link(longer), same parts were used on Granada...
    BTW the P/S steering box has a quicker ratio than does the manual...
  7. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Where do you live? I took off my pump, gearbox and centerlink off recently and will not be using them.
  8. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
    Okay thanks for the info much appreciated
  9. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
    I am in New York westchester county
  10. 71gold
    my point was people are removing them so he may be able to get what he needs from a board member...
  11. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
    Well the thing is I'm buying a parts car for dirt cheap because I need the front bumper balances and bracket and a couple interior stuff and noticed this one had power steering so I asked the question if it would be hard to do just in case if I wanted to do it...
  12. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
    Valances
  13. 71Mavrk
    71Mavrk Member
    Nevada
    If you do it, get a rebuild kit for the ram and valve assembly. Cheap and easy to do yourself. Get new hoses too.
    Micah
  14. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
  15. DonnyG123
    DonnyG123 Member
    1974 Ford Maverick
    Why is everyone against power steering ? Why do most people prefer manual
