power to man. steering ???
Discussion in 'Technical' started by 71gold, Apr 22, 2005.
  1. Grabber351
    Grabber351 Quick
    NH
    1973, Maverick Grabber
    Found my receipt, American pony.
    Code Name Quantity Price/Ea. Total
    700208 POWER TO MANUAL STEERING CONVERSION KIT 1967-70 1 $99.90 $99.90
    802033 INTERIOR LAMP LENS 1971-73 Dome Lens 1 $3.50 $3.50
    Shipping: FEDEX Ground: $10.34
    Sales Tax: $0.00
    Total: $113.74
    http://www.americanpony.com/store.mv?p=700208
  2. 71gold
    thanks,
    i found this in mustang unlimited...'65-'70 conversion kit. it utilizes the existing
    control valve end housing, seal clamp and
    ball stud for original appearance....$64.95
    i think i will order this and see what it is. if it works then i saved a buck or two...frank...:bouncy:
  3. 74merc
    74merc computer nerd
    1974 Comet
    I paid $130ish for mine including shipping.
    I'll put it this way, I can't see ever going back to power assist. The car is so much tighter now it really doesn't feel the same.
  4. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    Thanks guys, I needed this part. I just ordered the one from American Pony for 99.90. I'll let you know how it works.
    -Erick
  5. 71gold
    erick,
    post us a pic of the part when you get it...frank...:bouncy:
  6. 74merc
    1974 Comet
    It is nothing more than a control valve with the control valve portion removed and blocked off with a screw in plug. The control valve is spring loaded to control the power assist, the manual adaptor has no spring. Both have the grease fitting in the same location. It could easily be made from the stock control valve with a rebuild kit and the a large (7/8 or so) plug.
  7. scooper77515
    How can I do it with the stock control valve, what do I need to do to get rid of the powersteering pump and the play from the valve?
  8. 71gold
    ok boys and girls,
    i went to mustang unlimited today with my bride. while i was gone my boy (chris) took the power steering off the mav. i went to get the conversion piece for the swap. they have a plug kit for your valve.$65 bucks. i was going to get headers also but they were out of stock. chris didn't know this so he went ahead and cut the pipes out from under the car and pulled the stock manifolds off .:yup: he's such a good boy...(y)
    on the way home he called and asked me to pick up a set of pads for his front brakes on his truck...he had the brakes pulled and was waiting for pads...:huh: i know i was gone a few hours.. but i wasn't gone all day...
    when i got home he did his brake job and i did the mod. on the valve. this is one i pulled off at the junk yard yesterday...i have it ready and will put it on tomorrow...then try to put everything back so i can test drive the no power set up...pics. in next post...frank...
  9. 71gold
    the parts that come in the kit....next is the assy. put together...frank...:bouncy:
  10. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    does it matter what year it's going on? or will that work on all of theme? The american pony one that is.
  11. 71gold
    david,
    not sure about the year thing. they had no year one the parts i got....strange you mention ...american pony...the package i got the parts from ...mustang unlimited had ...american pony..on it...frank...:bouncy:
  12. scooper77515
    Did that kit get rid of the back and forth play that the knuckle had in the power setup? IE the piece that sticks up throught the rubber with the nut on top. I assume that big screw/plug in the side forces everything to stay still, but give a bit of adjustment?
  13. 71gold
    scooper,
    "I assume that big screw/plug in the side forces everything to stay still, but give a bit of adjustment?"...NOT !!
    the two solid cyls. are put into the valve then the heavy duty spring....i don't know what the big bolt does..:huh: i am putting the valve on as we speak...let you know what happens...frank...:bouncy:
  14. scooper77515
    keep me informed.
  15. 71gold
    WELL I CHANGED MY MIND...
    i didn't put the valve on..i think i will wait untill i get the headers on...another post...frank...:bouncy:
