Power Trunk Release?...
Discussion in 'General Maverick/Comet' started by TeeEl, Jul 8, 2021.
  1. TeeEl
    TeeEl Senior Member
    Colorado
    Can someone recommend a good power trunk release for Maverick/Comet?...
  2. 71gold
    One from an early Cougar will work. I have one around here somewhere for my car.
    Jeff will have the info you need.... rthomas771
    TeeEl likes this.
  3. rthomas771
    plynch, 71gold and TeeEl like this.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    One other question; I noticed that Melvins & AutoKrafters list a trunk latch for '70-'72 Mavericks but not '73-'77.
    Is the '73-'77 latch different from the early models?...
  5. rthomas771
    Only difference that I know is the way the lock attaches to the tail panel. 70-73 uses a horseshoe clip and the 74-77 uses a long bracket.
    TeeEl likes this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    Does anyone know if one from a '72-'75 Lincoln Continental will work in a Maverick?...
  7. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I had some issues with doing Jeff's mod to my '71, detailed here: My '71 Build
    TeeEl likes this.
  8. lastchance
    lastchance Member
    Hingham , Massachusetts
    I used one from a 1976 Lincoln.MarkIV
    TeeEl likes this.
  9. TeeEl
    TeeEl Senior Member
    Colorado
    Is it a bolt-in? Or is modification required?...
  10. lastchance
    lastchance Member
    As i remember it was just a bolt in.But that was about 8 years ago.
  11. TeeEl
    TeeEl Senior Member
    Colorado
    Thanks. I'm gonna take a chance & try it...
  12. lastchance
    lastchance Member
    I would have to look at mine to see if the ebay one was right.I had 2 locks and may be confused.I can look at it tomorrow.
    TeeEl likes this.
  13. lastchance
    lastchance Member
    Just looked at mine.Looks the same.
    TeeEl likes this.
  14. TeeEl
    TeeEl Senior Member
    Colorado
    Thanks. I'll give it a try...
  15. TeeEl
    TeeEl Senior Member
    Colorado
    So nearly 2 years later...
    I decided to install the power trunk latch that's been sitting in my toolbox for almost 2 years. It's from a '72-'75 Lincoln. Well, it was a FAIL.
    The latch functions perfectly on the "bench", but soon as it's bolted onto the car, the mechanism will not latch or un-latch. Bolting it in seems to tweak the housing just enough to prevent it from working, which is a real bummer because I really wanted a power trunk release in my Maverick...
