Power Trunk Release?...
Discussion in 'General Maverick/Comet' started by TeeEl, Jul 8, 2021.
  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Can you shim it to eliminate the binding?
  2. TeeEl
    TeeEl Senior Member
    Colorado
    RMiller likes this.
  3. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Is the striker not quite positioned right? If it's not quite sitting right it could take an extra hard slam to get it to latch, but hold the latch too tight for it to open properly.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    Yes. It's not a striker issue. The latch will not function when bolted in, but will function when not in the car...
  5. kansasGRABBER
    kansasGRABBER Member
    Hoisington, ks
    I used one from a 91 grand Marquis
  6. TeeEl
    TeeEl Senior Member
    Colorado
    What was involved in the installation?...
  7. kansasGRABBER
    Hoisington, ks
    I don't fully remember it's been a few years, but I believe just bolt it in and run a wire to a momentary switch under the dash. I can take a look Monday and post a picture
    plynch and TeeEl like this.
  8. kansasGRABBER
    Hoisington, ks
    Took a little longer to get
  9. TeeEl
    TeeEl Senior Member
    Colorado
    So it just bolts right in?...
  10. kansasGRABBER
    Hoisington, ks
    You have to grind around the pivot rod a little to shift it to the passenger side like 1/4 in. Otherwise yes
    TeeEl likes this.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    I installed and wired up one of these when I did my build. Mine went right in with no modification.
    I could never find a switch that would fit in the bottom lip of the dash. So, I never hooked it up. Some '80-'90s cars use to have a small push button switch in the glove compartment that was even marked trunk release. I have not seen any in the junkyards.
    I would be interested in seeing what you guys are using for the switch and how it is mounted.
    Micah
  12. kansasGRABBER
    Hoisington, ks
    I just used a cheap momentary switch from O'Reilly's. Found a pre-existing hole under the dash and enlarged it a size or 2 to fit the switch
    TeeEl likes this.
  13. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    upload_2023-10-16_18-29-10.png I have a few of these snagged off of Crown Vics
  14. 71Mavrk
    71Mavrk Member
    Nevada
    Those are the ones I remembered. Were you able to get them into any existing holes in the dash? If not, how did you mount them? Just looking for some ideas.
    Micah
