powerglide to ford
Discussion in 'Technical' started by Bean404, May 27, 2004.
  1. PaulS
    Can I have your C-4?
    I'm in Seattle, Washington.
    PaulS
  2. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Bottom line, find someone that knows C-4s, and not Powerglides. They are modified differently and you have to know what you're doing. I sure wouldn't keep taking it back to someone that can't fix it right. Unless you like taking it out? Powerglides are a piece of junk. Especially if you get a factory one that someone modified. Glides got their big following because for a long time there wasn't a 2 speed trans available. If higher HP cars 2 gears was all you needed, so lots of R&D went into it. The housing are very weak and will crack and break on you. The old cast iron ones are very heavy to.
  3. mavman
    mavman Member
    Arkansas
    sounds like rickracer doesn't like powerglides :oops:
