Pro-Comp Heads. Educate me.
Discussion in 'General Maverick/Comet' started by silver70, Apr 16, 2014.
  1. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    I am still going with the E-streets, but I just think it's interesting the two guys that have, actually, stated they ran them on their own cars have this to say:
    So, basically, they work... just not great. Just playing "devil's advocate" here. :mischeif:
    Again, I will learn from everyone else's mistakes and take their advice, but, the results are not consistent across the board. Only the majority opinion is prevalent. I am also a member of the FSB forum which is geared around Broncos and a lot of the guys over there love Pro-Comps. Some of them with serious rigs. Different application, but, same concept: cheap parts that do their job; even if not spectacularly.
    That was, actually, one of the reasons for this post. I advised a new member over there against Pro-Comps because of what I remembered about their reputation 10 years ago. I was "disagreed" with by several other members. So, I figured I'd post here, where the members are more familiar with building motors and not lift kits. :D
    Here's a couple quotes from the guys over there:
    BTW happy Easter to all you guys and your families. Hope it was a memorable/enjoyable day. :thumbs2:
    Eric
  2. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    By the way Pro-Comp Lifts are not the best either.
  3. Krazy Comet
  4. darren
    IVe purchased two pro comp products. One being a fuel pressure regulator. What a cheap piece of scrap metal. Taping it gently with a screwdriver would change fuel pressure 4 psi. Thats a ton on a carb engine. IT left me stranded on the first test drive. Not returnable. I run screaming from anything that says pro comp as a rule now. Cant imagine spending time and money for pro comp heads.
  5. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    I had to get a cup of coffee just o finish the "item description." Now there's a seller who doesn't have anything to hide! He'll tell you , too! LOL! I've never seen negative spacing between lines of text before.
    Eric
  6. darren
    Damn he almost had me convinced...... quite the write up!
  7. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Nowhere in that epistle was a flowchart, one of the most important considerations in choosing a cylinder head. That's coming later:16suspect
