Problem after Trans rebuild
Discussion in 'Technical' started by Jory, Feb 26, 2013.
  1. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    My thoughts would be did it vibrate when it went to transmission shop? If not it shouldnt have when it left. Subscribed to this.
  2. 71gold
    3500...and it downshifted...or you downshifted it...:huh:
  3. Jory
    Jory Member
    Greenville, Texas
    1971 Ford Maverick 4-door
    The trans had downshifted (from a lower RPM/speed) and was up around 3500 RPM when it threw the rod. It's an automatic.
  4. 71gold
    (y)...you were winding on 2nd. when the rod turned loose...:cool:
  5. Jory
    Jory Member
    Greenville, Texas
    Well, I wasn't really getting into it much as it was probably about to shift back to third. 3500RPM isn't too far removed from the 3200RPM my car cruises at just going down the highway at 70mph.
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Doesn't sound like abuse. Hope the engine builder covers it but I suspect the flexplate or torque converter wasn't properly imbalanced/balanced and it broke the engine. Expect the blame game will begin.
    You can personally verify the part number on the flexplate now to be sure it was correct.
  7. Jory
    Jory Member
    Greenville, Texas
    I believe that the flexplate went back to the motor rebuilder but the trans rebuilder kept the TC though. Yeah, I'm hoping that they don't start blaming each other and leave me in the middle without a car and neither side taking responsibility for the problem.
  8. Jory
    Jory Member
    Greenville, Texas
    Ok, got the news today. I talked to the motor rebuilder and he said the dipstick tube that the guys put in after the initial motor rebuild 9 months ago wasn't seated in the hole in the timing cover and that it looked like the motor had run out of oil. I told him that I had checked the oil level just a few days prior to the rod being thrown and it was good, and that when the rod left a hole in my oil pan it dumped a LOT of oil out. I've never had a leak around that area before, so who knows. Anyway, he said the motor wasn't salvageable and that he was going to have to build me a new one. I asked how much this was going to cost me for the new motor and he said....."Nothing on your end. I'm getting the parts together right now and it won't be done until next week, but I think you'll be happy." WOO HOO!!!! :yahoo: Now I just will need to find out what the cost will be to get it all put back in the car, or if that is going to be covered too. Either way, it's all going to be cheaper that I expected.
  9. 71gold
    you going to run the same transmission...:rolleyes:
  10. Jsarnold
    '72 Sprint
    You'd better be sure of the (im)balance of the flexplate and torque converter before the new engine goes back in. Not that I'm mention it to the engine builder. :oops: Maybe he knows what REALLY happened to your engine and balance wasn't the issue ... or ... maybe not.
    Also, be sure you know whether the crank in the new engine's crank needs 28 or 50 oz harmonic balancer and torque converter. He could be using any 302/5.0 core to rebuild. I'd also ask about the firing order, if he doesn't install plug wires, and flat or roller lifters.
  11. Jory
    Jory Member
    Greenville, Texas
    He knows what vehicle the motor is going in, so I hope that he tries to keep the motor from the same era for firing order/balance/etc., but we'll see. I'm going to give him a call on Friday to check on the progress.
  12. 71gold
    I would hope he goes with a later roller motor...:thumbs2:
  13. Jory
    Jory Member
    Greenville, Texas
    Well, he already had the block (I have no idea what year) and is now gathering everything else to build up the new motor. At this point I don't care WHAT year it is...I just want to have something that works right the first time and lasts me a good while.
  14. 71gold
    late model...roller motor...if starting from scratch...:yup:
