Problem test firing 302
Discussion in 'General Maverick/Comet' started by chandler, Jul 4, 2012.
  1. chandler
    chandler Member
    Warrenton Mo
    Maverick
    I changed the condencer that solved the probelm of it firing correctly at the coil. As the motor is cranked it goes from 11.6 volts to 0.0 as the points open and close.
    Again I took out the #1 spark plug no spark, tried a different wire that I had on the shelf still no fire on at the plug :hmmm:
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If you have fire at the coil but not at the plug then it seems like it has to be the cap or the rotor.
  3. bmcdaniel
    bmcdaniel Senile Member
    What happens if you crank it while touching the big terminal of the coil? LOL
  4. sdb416
    sdb416 Member
    TEXAS
    No Maverick now
    This is actually a good idea and very painful.
  5. chandler
    chandler Member
    Warrenton Mo
    Maverick
    I have gotten a new cap and rotor which were new. At this time I am willing to double up heck the condensor helped :)
    I believe bmcdaniel is referring me to use a tester on it.
    Thanks everyone and hopefully I can work on it tonight.
  6. bmcdaniel
    Actually, I was refering to your finger. :D
    You'll know right away.
  7. ThisFords4U
    ThisFords4U Member
    Southern Oregon
    '72 mav
    OK. I reread this twice, trying to make sure what you have done. you said you have proper "spark" ?? at the coil, but 0 volts on the neg terminal, but yet no spark at the plugs (with new cap and rotor). I would double check my connections in the cap Sometimes the rotor to cap terminal is missing inside the cap, coil wire terminal inside cap missing, rotor tab not bent up enough. use your ohms meter and check continuity of coil wire, check that the inner wire is connected to the wire terminals. double check the wire from neg term on coil to the dist isnt grounding out when it enters the dist. OK rethinking this as I reread it If your getting spark at the coil but not at the dist. its getting lost between the coil output and the cap. also what color spark do you have?
  8. chandler
    chandler Member
    Warrenton Mo
    Maverick
    I set another cap and rotor on the dist. pulled the #1 plug as I turned the key over I just bump the key instead of cranking on it yippee :thumbs2:I see fire from the plug. Excited to say the least so I go ahead and crank the motor with the plug out no spark again:cry:. Then I bump the key several times each time a spark I checked the connections and everything appears to be tight.
    The keyed ignition in the column is new also.
    As far as the spark color a brilliant white.
    Thanks to everyone that has put their input into my "problem" needless to say it gets a little flustrating :)
  9. ThisFords4U
    ThisFords4U Member
    Southern Oregon
    '72 mav
    So are we running??
  10. chandler
    chandler Member
    Warrenton Mo
    Maverick
    No not yet, I don't understand why aas I crank on it to start the motor I have no fire but if I bump the motor it has fire does that make sense?
  11. junrai
    junrai Member
    rancho cordova ca
    have you tried hot wiring it yet? I had a problem like this in an old ford truck and there was a wire that lead to my ignition switch that was just BARELY making connection.
    hot wire it and if it starts and runs you can A. keep beeting your head against a wall trying to figure it out or B, you can set up a starter button inside your car directly off of your starter cylinoid (sp?)
    I know its a hoakey way of doing things but it solves alot of headaches just hook it to your dimmer switch and you have a hidden starter switch
    do you know how to hot wire the car?
  12. chandler
    chandler Member
    Warrenton Mo
    Maverick
    I was just talking with the guys at work and that is what they suggested to about hot-wiring it that would eliminate the ignition and I could work from there. I will keep you informed as I get more time to piddle with it.
    Thanks
  13. mavman1970
    mavman1970 Member
    Minnesota
    This happened to me with my 79 Ford pick up but it had the electronic ignition in it. I was told this is called a hall effect and would only fire when letting go of the key. It never started when cranking but when I released the key it would start right up. I ended up replacing the pick up coil in the distributor. After typing all of this I think I remember you are running the points distributor? Anyone know how this would correlate?
  14. bmcdaniel
    I had that happen when I got the two small solenoid wires reversed one time...
    The small solenoid terminal closest to the starter cable feeds the ignition coil during cranking. If the wires are reversed the coil doesn't get any voltage when cranking.
  15. chandler
    chandler Member
    Warrenton Mo
    Maverick
    Tonight was a good night after looking at everything again I did have to 2 wires crossed on the cylinoid.Butta Boom Butta Bing I finally got to hear it!!!
    Thanks to everyone for their help
