problems with lights
Discussion in 'New Members Forum' started by smokiej, Feb 27, 2006.
  1. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    by the way thanks for taking timeout to help
  2. Mavaholic
    Does the lights come on & fade every time or are they not working at all now?
  3. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    no the headlight switch
  4. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    not working at all it just faded the first time i turned them on after work
  5. Mavaholic
    The headlight switch is attached to the knob that operates the headlights, in the dash. Its a bitch to change.
  6. Mavaholic
    I think you are probably not getting voltage through to the headlight switch then. Probably not a switch problem. You will have to find that wire that should be on the starter battery post that I mentioned earlier. That fusable link may have blown.
  7. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    how big of a bitch do i have to take the dash apart
  8. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    is it one of the smaller wires
  9. Mavaholic
    Read my last post, I dont think its a switch problem. I thought they came on & faded every time you turned the lights on. Because they dont, I doubt its the switch.
  10. Mavaholic
    It will be one of the thicker wires
  11. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    ok cool i'll have to check that out thanx agian for taking time to help
  12. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    earlieir you said it was on the soleniod so what type of fuse am i looking for
  13. Mavaholic
    ITs not like your used to seeing. What it will be is a thick wire with a big ring terminal that usually bolts on the solenoid post. It may be bolted to other wires and just insulated. Thats usually what happens when an amp gauge is installed. Directly behind the ring terminal, the wire will be real thick, more than twice the diameter of the wire. That is the fuse part. If you have a volt/ohm meter, its pretty easy to test it.
  14. smokiej
    smokiej Member
    marietta, ga
    74 302 2 door
    if i don't have one of those could i just use a jumper wire to test it
  15. Mavaholic
    You could cut it off, add another terminal and bolt it back to the battery post just to test.
