Project Humpty Dumpty
Discussion in 'Maverick/Comet Projects' started by HarleyGA, May 14, 2014.
  1. Paul Masson
    1971 Grabber
    WOW! That looks awesome! What did you paint your hood hinges with?
  2. Bryant
    i have that pan. i had to notch it to clear the lower control arm mounts. heres a pic of it
  3. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    For the hood hinges I used DupliColor engine paint DE1651 Cast Coat Iron.
    Paul Masson likes this.
  4. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Thanks Bryant for the pic of your oil pan. I have mine measured and marked off for modification but want to measure again. Makes me nervous that i'll get it back and discover that I overlooked something.
  5. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Humpty dumpty is coming along slowly. Wish I had more time to work on it. When I do get time it seems like I spend most of it looking for the tool or right nut or bolt. I'm off the rest of the year so I hope I can make some serious progress.
    Modified the Moroso oil pan to fit the Maverick.
    Underdash puzzle. Glad I took a lot of pics before I took it apart. Also got a great deal of help from members. THANX
    Clutch master cylinder linkage.
    Clutch master cylinder is down there somewhere.
    Dash and carpeting coming along.
    View of the passenger door. It looks perfect.
    The headliner took a long time. I'll never attempt another!
    maver88 and Paul Masson like this.
  6. mavgrab302
    It's looking great...
  7. mercgt73
    Wow! Looking awesome! I love the black and blue dash. Exactly the way I want mine to turn out.
    Did you use Medium Blue Metallic (16049) on the passenger door?
  8. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Nice work! Looks clean, clean, clean!!
  9. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Sure did. SEM's 16049 is a perfect match to the OEM.
  10. mercgt73
    Trying to get a can of this paint on the way. Are you sure it is SEM brand? I can find Accumatch distributed by Scott Drake and Rainbow Industries. Would you mind checking the brand on your can? I appreciate it! :tiphat:
  11. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    Is that clutch master the Modern driveline unit? If so what do you think of it to this point.
  12. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Only have the master installed. Nice kit. I can say any more until the car is finished.
  13. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
  14. mercgt73
  15. mercgt73
    I ordered a can of the SEM VP-16049 and the Seymour lacquer AP-16049 from NPD. One more question and I'll quit bugging you! Did you do all of your medium blue metallic painting with the SEM VP-16049?
