Project "Slow Go"
Discussion in 'Maverick/Comet Projects' started by bkcha, Sep 1, 2015.
  1. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    You can find a rusty tray for pretty cheap. The key is you need the lower bracket, the top tray can be bought new and welded on.
  2. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    I have the upper tray and apron already just need the support. I keep hearing someone is makeing the correct tray for our cars with the lower support. If this is true just trying to find out how it is.
  3. William623
    William623 Member
    Orlando
  4. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    Ok I have a 1993 302 block and the timing cover with mechanical pump provisions. Drivers side water pump. What bolts should I use. I have read and a bunch of people say don't buy the arp kit because most of the bolts are wrong. Anyone use a kit that worked for them???
