pulley problems. looking for options?
Discussion in 'Technical' started by Thomas, Sep 30, 2012.
  1. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    ok, ok. it was a bad idea. I didn't really want to spend the time trying to make it fit. It was a last resort kind of idea. I'm going to look for some after market pulleys.
  2. bmcdaniel
    So where did the v-belt pulleys come from? I had no problem using my old original pulleys on my 5.0 (which BTW I'm not using anymore).
  3. 71gold
    I just found you the right pulley...:Handshake
  4. scooper77515
    I looked the pulleys up on johnsmustang.com which happens to be local here. They sell water pump pulleys in various depths. So I measured how much more I needed, and went and looked at what he had in stock and got one that fit. Still needed minor shimming, but I mean like using a set of four thin washers, and they lined up.
  5. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    I returned the water pump. It was just not working. I am now in the market for another water pump.
  6. baddad457
    Yes, you're correct
  7. baddad457
    The rpms are of minor importance, the pulley grooves lining up are the most important thing. You can play around with the diameter to over or underdrive the pump to vary the coolant volume, just as you can with the impeller size. And in changing pulley size you can change the fan speed.
  8. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Why not go with a serpentine setup since you need to replace water pump anyways.
  9. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    I am wanting a more classic look going with the v-belt.
