...pulley ???
Discussion in 'Technical' started by 71gold, Jun 13, 2012.
  1. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    But your post count is a little different :thumbs2:
  2. 71gold
    just by 13...:huh:
  3. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    Here you go. It was in good shape when i took it off.
    Hey Frank
    You know when i talk on the phone to much my wife calls me a "rubber lip". So does this make you "rubber fingers"?
      File size:
      152.8 KB
      File size:
      153.4 KB
      File size:
      144.4 KB
      27
  4. 71gold
    OUCH!!!!...:outtahere:
  5. 71gold
    that bracket looks like just what he needs...(y)
    I'll check with him and see what route he is going to take...:Handshake
  6. krelboyne
    krelboyne Remember
    Salem, Oregon
    That is not a factory part. Someone drilled an extra hole in a power steering bracket, and mounted an air conditioning adjusting pulley.
  7. blugene
    blugene Senior member
    I like your nails :ignore:
  8. blugene
    Probably right. But I have seen that before.
    I wonder if there is any flex in it when in place and under a load..
  9. 71gold
    it's only driving the waterpump...:yup:
  10. 71gold
    we're thinking if we can find a waterpump pulley that lines up with the alt. pulley, we can do away with that belt all together...:thumbs2:
  11. blugene
    I made my own bracket out of a piece of angle and used the ac tensioner.
  12. 71gold
  13. blugene
    The engine has run with it.. [​IMG]
  14. Craig Selvey
    That is the way the FACTORY did it. :thumbs2:
  15. 71gold
    do you have the correct pulley....:yup:
