Putting torque back in
Discussion in 'Technical' started by Dean Deeter, Jul 24, 2005.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    No, it has not happened to me..
  2. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    Should Be About In 1/2 To 3/4 From The Edge Of The Bellhousing I Use A 7/16 Box Wrench And Put A Bolt In The Bell Angled To The Convertor To Keep It From Moving Till I Get It Lined Up
  3. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Never done that before. Might try that.
    I usually have someone helping me line it up anyways so one of us holds it anyways, but that could help out a lot
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I never knew that about putting the convertor back in. Glad I learned,, I gotta put one back together.
    Dan
  5. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Hey Andy, My flywheel is welded onto the torque so I do not need to worry about this. But thanks for help. Dean
  6. Andysutt
    Conway Arkansas
    1972 Comet GT
    Your going to have one hell of a time bolting it to the crank then.
  7. Dean Deeter
    Dean Deeter Member
    Your right any ideas on what is the easiest way:hmmm:
  8. kansas_grabber
    kansas_grabber Member
    Lawrence, KS
    73 Grabber
    i have a 75 dodge van that has flywheel attached to the torque converter. it uses a flexplate to go in between the converter and the crank. is that how your mav is set up? if so, what engine do you have in it. just wondering.
  9. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I am assuming it is a 200ci six cylinder. The teeth are made to the converter. There is a Flywheel but it looks more like a puck. Not that hard to bolt back up. If you have a 302 and they welded the flywheel to the torque converter I suggest starting over with a new flywheel and converter.:)
  10. Andysutt
    Conway Arkansas
    1972 Comet GT
    Never seen one of those converters w/ the teeth. hrm
  11. Dean Deeter
    Dean Deeter Member
    Yes this is a 1974 maverick with a 200 six. I have a 250 six that will be going in next spring. It has a different bell housing and the flywheel is bolted to the engine. Yes it has a flex plate that the torque bolts to.
