Question for the 4 speed Manual tranny Guys
Discussion in 'Technical' started by DaMadman, Nov 19, 2008.
  1. rthomas771
    My tag reads wide ratio 390 Fairlane but it's a close ratio gear set with a Mustang tailhousing. I figure someone needed to replace the box when they rebuild it and used what they found.
  2. rayzorsharp
    I'm running a Comp Plus shifter too. I tried a Super shifter and it mounted too far to the left and made it tough for using a console. On the Comp Plus sfifters you can find them with different offset at the top of the shifter to move the handle further towards the center. Works much better with my console now.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Make sure to check the input shaft!
    A 390 input looks like a 302 input at a glance. You have to measure the crank bushing surface to know for sure. They are not interchangeable. To run a 390 tranny on a 302 will ruin the tranny.
  4. rthomas771
    The 289-390 used the same 1 1/16" input shaft. The 427-429 used 1 3/8"
  5. ratio411
    ratio411 Member
    Pensacola
    Jeff,
    The bearing surface that goes into the back of the crank is different...
    The 289-302 tranny is too long and won't stab into a 390 fully.
    Then the 390 tranny is too short for a 302 and won't support the input shaft, destroying the foward main bearing in the tranny.
    There are ways around it... but you have to know what you have to make mods.
  6. ratio411
    ratio411 Member
    Pensacola
    Here is the pilot bearing surface.
  7. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Bought mine in '74, also paid 100 bucks ,AND...I lived in Clearwater/St.Pete area then...that is amazing!
    We threw it in at my buddies gas station in Clearwater Beach one night and somehow the shift pattern was 2,1,4,3...drove it for 2 days like that,until we got a chance to fix it..Jack
  8. ratio411
    ratio411 Member
    Pensacola
    The junkyard had taken mine out with a torch!
    The only bolts that were undone on the whole thing were the bell bolts.
    I got the tranny with the center of the crossmember still bolted to the rear mount. The original Boss Hurst shifter was still on it, like I mentioned, but they torched off the tee handle! Rather than unscrew it to get it out the bottom easier. The speedo cable was cut with dykes (or bolt cutters), and the first inch or so of the driveshaft was hanging on after being torched.
    Can you just picture some yayhoos going around a Boss 302 with a torch removing parts?!? Even if it was wrecked, every nut and bolt on the car would receive tender loving care nowadays.
  9. DaMadman
    Southern MD
    Maverick 1972,1970,1973
  10. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
  11. Mavaholic
    I bought mine from Pat's Speed Shop down in Park Hall, MD. It was an old NOS kit from the 60's which according to Pat, had much better parts than the stuff out now. His number is 301 863 2111.
  12. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    My Toploader was in a 65 Mustang ... it came with the Hurst Comp Plus shifter already mounted ...
  13. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Mine had the competition plus shifter on it. But with the Liberty I'm running a V-gate.
  14. fordride
    fordride Member
    granby qc canada
    72 grabber !, 63 ford country sedan, 70 maverick 6 cyl 250
    Super suiffer 3
    I Want to Know if you have any pictures of your tunnel work to instal a super shifter 3 on the maverick tunnel ???
  15. baddad457
    HUH? :hmmm: Not just an old thread dig here, but unintelligeble too.
