Question on a Oreilys distributor
Discussion in 'Technical' started by A1973Maverick, Jan 20, 2025.
  1. A1973Maverick
    A1973Maverick Member
    Indiana
    1973 Ford Maverick
    Thanks for your help as well really apreciate it. Yes your correct they switch the positions somwhere in 77 I belive. Mine is on the left side of the engine so it threw me off for a second but then I figured it out. I have no idea what my dwell is but thats for another day. I am currently working on plumbing the transmission cooler lines etc so I can put fluid in the trans to run the car I couldnt have done it without you folks.
    I have a flip phone or what they call a dummy phone LOL so I havent got good videos but this weekend ill get some folks with some new phones take a video of what I got going on so far.
    Still have to do quite a bit of stuff to do but the fact that it runs means I can throw some bolts in the motor mounts and change the filter in the transmission. Hopefully I have a good transmission on my hands we will see once I throw the brakes together and put the driveshaft on.
  2. Krazy Comet
    Dismal Swamp
    Probably the first engines with dipstick in passenger side block were '78 Fairmont(bye-bye Maverick) & '79 Mustang both are Fox chassis. Those are rear sump pans, I guess they could work without belly bar installed (I honestly dunno).
    I converted my '91 Mustang 5.0 to front sump when I installed it in Comet. If you have a front sump, dipstick will only read correctly from timing cover in right front of engine.
  3. A1973Maverick
    Indiana
    1973 Ford Maverick
    I have a rear sump in it currently. I got it to fit but I think I need to make a pan for it that way if anything hits it
  4. A1973Maverick
    Indiana
    1973 Ford Maverick
    I stand corrected its a front sump but im not sure if I converted it but I made sure the pickup was in the right place. I suppose if it wont read correctly I can throw a fresh 5qts in it and mark it I have a 5qt pan
  5. Krazy Comet
    Dismal Swamp
    A rear sump pan will not fit over the front sump oil pickup. Or vice versa.
  6. A1973Maverick
    Indiana
    1973 Ford Maverick
