Quick disconnect for dash gauges....
Discussion in 'Technical' started by mashori, Aug 5, 2012.
  1. MSmithPDX
    MSmithPDX Member
    Portland, OR
    The main thing you want is something with enough connections for your devices, and enough body so that you are never pulling on wires to separate. Also look for non locking connectors. If it snaps into place it's not made to be removed more than once or twice. If it twists into place it's designed to be removable.
    Then when you are wiring your connector put your signal wires and power wires on opposite sides of the connector whenever possible, with the grounds between them is actually best.
  2. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    That military spec connector is the same one JLG uses. Go to any JLG dealer and they can get it for you.
  3. mercgt73
    mercgt73 Member
  4. bmcdaniel
    Duetsch makes good automotive connectors. We use em on 90% of the automotive harnesses we build at my company. I think Summit and Jegs sells them.
  5. mav1970
    That was a brand that we used a lot at Altec - I still have some laying around in my tool box :thumbs2:
  6. bmcdaniel
  7. mav1970
    Yup, remember them well - do you work for AMP?
  8. bmcdaniel
    Our company is in an old AMP building in Seven Valleys, about 9 miles south of York. Mercury Electronics, we build wire harnesses, cable assemblies, panels.
