Quick, dumb question from someone that should know the answer already.
Discussion in 'Technical' started by courier11sec, Oct 15, 2004.
  1. courier11sec
    courier11sec Member
    Tucson, AZ
    Will a 250 six bellhousing bolt up to a 351w?
  2. fordman
    fordman Member
    lufkin texas
    1972 maverick
    i think they did but they had the 6cly drums in them i think i got one out of a granada 250 one time that had a 302 351 bell
  3. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Yes, they will. The 250 has the same bellhousing as the 302 and 351. They'll bolt right up. New project??
    -Corbin
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    Thanks fellas.
    Corbin, a guy that just found this board recently contacted me about making a hot rod out of his newly acquired 1972 Comet GT. really great foundation for a hot rod. Factory buckets and floor shift just needs the powertrain gone through and some elbow grease and it'll be a great car.
  5. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I never heard of a 250 bell for a 302 or 351. You are going from an inline 6 to a V8. Come guys I find that hard to beleive.
  6. Corbin Johnson
    I know, it sounds silly, but it's the truth. The 250 is the "big block" six and it was specifically designed for the 302/351 bellhousing.
    From Fordsix.com: "At the rear of the block, the 250 was redesigned to accommodate the same bellhousing pattern as a small block Ford V8. "
    http://www.fordsix.com/200-250.htm
    -Corbin
  7. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    mike75mav, I`m using a 250 C4 bell on my 302 ...
  8. Mavaholic
    Its true enough. Pulled a 250 out of my 77 I used to have and dropped a 289 right in. Same trans.
  9. mike75mav
    mike75mav Member
    Bremerton, WA
    OK guys I'm conviniced. You got me.
