Race weight
Discussion in 'Drag Racing' started by stroker mav, Apr 21, 2015.
  1. Rick
    Rick G8I operations
    Ocala, Florida
  2. Paul Allen
    Paul Allen The Maverick is back!
    Middleburg Florida
    1972 Ford Maverick
    Very impressive numbers today on the dyno! Congratulations!
  3. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Congratulations on some impressive numbers. Did Ron work the heads as well as flow them?
  4. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    rotorr22,Thanks,I got the heads off ebay, they were on a 331 twin turbo car and the port work was very good as you can see by the numbers. Ron just flowed them.
  5. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    With that much flow those heads should make very good power.A high HP car that is a little heavier is a good thing for traction,also,on a windy day a light car can become a real hairy ride going through the traps at high speed.
  6. Rick
    Rick G8I operations
    Ocala, Florida
    Very true, on my 70 I had to cut the coils to get the nose down because it felt like it was floating through the traps. Not a good feeling at any speed.
  7. Boss302maverick
    Boss302maverick Member
    New Jersey
    1971 maverick grabber
    My car weighs 3050 with me on it, I'm 250, and I run a Boss302 with a c4, 9" rear, 8 point bar with subframe connectors, stick fuel tank and all steel and glass, full interior, just heater box pulled out.
    tbirdz12 likes this.
