Radiator exploded
Discussion in 'General Maverick/Comet' started by PAINTANK, Jan 4, 2010.
  1. Bryant
    :ttiwwp:
    lets see, let see, lets see.
    scoop, you sound like you may have some personal experience with that scenerio. that is when i would want my fan on. when the car is siting with out airflow across the rad.
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Keep in mind all I had was a pen torch and it was COLD and dark...
  3. Bryant
    good job and thanks for the pics.
  4. darren
    Good fix. Is that rusty mess on the top of the rad your coolant???
    If so thats going to be really tough to get clean. Lots of flushing in your future.
  5. PAINTANK
    1973 Comet 2 dr
    Flushed that engine twice and it's still rusty colored. As long as it cools I don't care. Hope this holds.
  6. darren
    I hear ya. Its really tough to get rid of it once its rusty. Just back flush it best you can and make sure you have good anti freeze in it. The additives in the glycol are important. You'll never get it clean but as long as its not corrosive anymore thats the best you can do.
  7. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    Good job and you didnt get fired..:dance:
  8. blugene
    Looks boogery. :rofl2:
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Looks great to me! And in all likelihood a permanent fix. Well done!
  10. simple man
    simple man Member
    Bunnell,Florida
    Mine did that awhile back and when I took it to the shop I was told to use a 7lb cap. This man is very knowledgeable and said you do not need a high pressure cap. My car has no problem with running hot here in Florida,in the summer,with factory air on. I haven`t had a radiator problem since. He told me the high pressure cap makes the tank swell and contract with heating and cooling,which causes the seams to split.
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Looks good! They make rad flush to help clean inside out. When your all done, just,,,, ready,,,,, PAINTANK! black of course,, I been waiting to do that!
  12. blugene
    Makes sense. I also thought I read somewhere that our radiators full leval is actualy about 1" down from the top. If you add a resivour then it (the radiator) will/should be full to the top when checking.
    :sarcasticclap:
    I been waiting to do that! :D
  13. PaulS
    Usually a tank seam flexes too much to hold a plain solder repair. I use a piece of brass, folded over to fit tight in the area of the split and then solder the brass piece over the split. That holds well.
  14. PAINTANK
    1973 Comet 2 dr
    Well I drove it 15 miles to work this morning, Frosty crystals on my windshield. My heat kicked in HOT about 3 minutes after starting as usual and there was no steam or drips the whole way. I placed a cardboard under the nose to see if it was leaking and there were no drips all day. After work I drove to Autozone for a better fitting lower hose, remember the new tanks hose tube is narrower than my original, and there were no drips. Overall I drove about 35 miles today with no issues at all. I am pleased with this repair so far. If it was going to do something it would have during the first 10 miles I'd suspect and a drip would have happened.
