Ralph Price's unrestored 1971 Grabber
Discussion in 'General Maverick/Comet' started by dmhines, Jul 5, 2006.
  1. Craig Selvey
    I know I have seen some Mavericks with the one with insulated posts. I seem to recall the 1977 I am currently parting out has it. If it does...I will check it out.
  2. Greengrabber
    Greengrabber Member
    1971 Maverick Grabber
    Anything is possible, I started thinking that maybe I had changed it, even though I don't believe I did, so I went and took a good look at it. On one mounting flange it has the part# C9AF11450A and on the other Autolite P1ED (or P1E0..I can't quite tell right now, its dark under the hood....). So I think it is original. If I had changed it at any time other than within a few months of it being new the part more than likely would have said Motorcraft. So my vote is that it is original.
  3. Greengrabber
    Greengrabber Member
    Oh ya, do you think the P1ED could be a date code?
  4. Jamie Miles
    Alto, GA
    I've had a few
    C9AF would be a '69 part number. Intresting...
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The Ford Parts Manual does list that as a valid part for all 65-71 Ford Cars ... suppose that's what the assembly line had in the parts bin that day ... cool ... I wonder if there is any benefit to running that style of the original. I assume it uses the same mounting holes on the fender apron.
  6. Jamie Miles
    Alto, GA
    I've had a few
    Seems to be a better made piece. The one on my grandpa's Aerostar had 233,000 miles on it when I replaced it. And it is an exact replacement for the older style, because I put an older style on the Aerostar for a while until it, to, quit working.
    I have been meaning to crack one open and compare the internals to an older style one, just haven't got around to it yet.
  7. dmhines
    Cumming, GA
    Perhaps they were not restored properly ... but a quick google image search does not show any 1969 428 CJ car engine compartments with that solenoid ...
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I can't add anything more to the well-deserved "Wow" comments except, "Wee!".
    Okay, what are the witness marks on the rear springs?
    (p.s. I don't believe that is "Grabber Green", correct? What color code is it please? Very nice color whatever it is.)
    Look out Barret-Jack$on!
  9. Greengrabber
    Greengrabber Member
    Thanks Rick.
    The springs were color coded with paint stripes according to their spring rates. Mine has the heavy duty suspension. Build sheets will show the colors of the stripes for both the front and rear springs, also for such things as sway bars etc. The color doesn't have a fancy name, just "Dark Green Metalic" code C.
    Ralph
  10. Rick Book
    Rick Book Member
    Thailand
    Good info. Thanks!
  11. rayzorsharp
    Dan, it does use the same mounting holes.
  12. Mavaholic
    I have seen that solenoid a couple of times. I think my 71 has it.
  13. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    I have that same solenoid on my 90 Bronco 2.
    Okay. Extremely nice car. (y)
    If he ever decides to part it out on the board here, I got dibs on:
    Hood
    Front and rear bumpers
    Engine
    Transmission
    Rear end w/springs
    Complete interior
    Disc brakes
    Brake booster w/master cylinder
    Grille
    Front turn signals
    Front valance
    Rear valance
    All 4 side marker lights
    Headlight Bezels
    Sport Lamp switch, if equipped.
    Radiator
    Yep, that's about it. That's what I want. Anyone else need anything?
    Seriously. Nice car. It must have been hard not taking it out for a drive or making it a daily driver. :drive:
    (y) :bowdown: :bananaman
  14. Rando76
    Rando76 Member
    Claremore, OK
    ...wow
  15. Jamie Miles
    Alto, GA
    I've had a few
    It's a direct replacement.
