Rat rod project . . .
Discussion in 'Other Automotive Tech & Talk' started by mashori, Jul 21, 2011.
  1. stmanser
    Davenport, Iowa
    the look on the lady in the picture says it all
    ???(*&()*&^(*&%(*^%%TYUT*&H(&%^&$%^$%??
    lol
    looks pretty cool. i was thinking of doing a rod myself... just need to find the right canvas
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Here's some pics of mine Mo, 36 Dodge cab on mid 80's Toyota pickup frame.
    I plan on a 302 C4 for power, with a Mav 8" rear to replace the Toyota rear. Will probably use Corvette bucket seats, not sure about the steering column yet. Waiting on it to cool down a bit here before I start mocking up the motor and tranny, then I can hang the pedals and do the floor.
  3. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Wow, I thought I was the only one with a Toyota frame. I had problems with mounting my 302 in the frame, wound up with a fox body oil pan, then the trans hits on the torsion bar crossmember.
    You may have a better time with your pickup, I tried to get the grill as far back as I could on my sedan, which caused some of my problems.
    That concludes my thread hijack.
  4. ford84stepside
    Berry Alabama
    I'm doing away with the torsion bars and going with coil overs to have more room.
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    got the steering off finally
    needed to remove the headers
    quality work here
    bolts that were used to hold the body to the frame
    some of the welding inside the cab that was done by PO
    I removed the wiring and had the guys at the shop help me lift the cab off the frame, we just kind of rolled it, worked great
    I can't get this pin out, is there a trick?
  6. Dave B
    Wow, I missed this...that's pretty cool!! I've always wanted to build a truck like that.
  7. cyclonewill
    cyclonewill Member
    Center punch, and drill is what I used to get the hinges apart on my 31.
  8. lastchance
    lastchance Member
    Hingham , Massachusetts
    That looks like a great start !
  9. Bryant
    whats with that distributor being on the wrong end of the motor?
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So we made a list of things that need to be done, I want to do it as cheap and as much from recycled parts as possible.
    We are gonna start with rebuilding the tranny (turbo 350), needs a TQ also.
    Brakes for the front and rear, ranger diff in the back, don't know what spindles are in the front.
    Have to figure out the head lights
    Need master cylinder and pedal
    Harness for turn signal and brake light (might try a trailer light set)
    Idiot light for oil, voltage, water temp
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I could use some suggestions on how to do my lighting on this truck.
    these are the headlight housings that are in place. I want to do something really simple, no intention of buying expensive parts to make this work.
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Is there aftermarket lighting kits? Bryant mentioned getting trailer lighting kits?
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  14. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    Those look kinda like the headlights for a 38 ish chevy.
  15. cyclonewill
    cyclonewill Member
    I got a pair of buckets with sealed beams brand new for $40 after walking past several over priced pairs of Guides at the swapmeet. They will fit your stands. Speedway sells them as dietz lights PN:911-01008
    May be cheaper than trying to find the parts to fix the ones you have.
