Rat rod project . . .
Discussion in 'Other Automotive Tech & Talk' started by mashori, Jul 21, 2011.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    super cool project..starting to come along very well.
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    so found out the casting on the engine makes it a 305 and it's a late 1970's truck engine.
    The engine mounts are done, I mocked them up to where they should be sitting, just have to weld them to the frame next....
    Now the engine oil pan clears perfectly...
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    It wasn't easy but got the engine mounts positioned just right and started welding them....
    All welded up
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Tranny mount
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    The cab back on...
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Gas tank....
    Hit it with a shank....
    Then a tap for pipe thread....
    Locktite...
    Barb fitting and that's it.
    Next the vent....
    Used a brake line fitting....
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Looking good Mo! Wish I was that far along. You need to start a build thread with pics on RRR. I'm sure you will get lots of compliments!
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Been making slow progress the past few days... but it's ok, I'll pick up the pace soon....
    took apart the steering box, pretty straight forward, in the near future I will be putting the steering back together with some U-joints to be able to offset it some...
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    got the headlights installed....
    what a great kit this was from speedway motors...
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    the radiator got worked out well since we had a lot of radiator hose laying around the shop (I gotta replace what I ransacked)...
    Bry's idea to mount it close to the shop brackets...worked out well...
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    alternator is installed on the passenger side...
    I like the location...
    gotta make one extra bracket to keep it in there solid...
    the belt is a little too short, need a longer one....
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    the pictures aren't great, but the panhard bar was hitting the top of the diff housing, so I welded on (with a TIG welder, my first functional TIG welded piece) an extra nut to get the heim joint out further and then removed the tab where it was and welded it up higher....
    came out decent...or I should say, came out rat roddish!
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Got my driveshaft today after $200...
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    The driver side door didn't close properly, had to do some hammering and cutting and sanding.....
    Hard to see but the latch doesn't fully seat....
    I had remove the striker by stripping out the spot welds...
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Will need to drill some holes into the clutch pedal to bolt on the pedal pad...
    I will be removing the cab occasionally so need the brake pedal to detach easily
