Raw Small Block Ford Power
Discussion in 'Drag Racing' started by riporter, Jun 25, 2008.
  1. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    A few more!:burnout:
  2. rayzorsharp
    That is wicked! Totally Wicked!!! (y)
  3. riporter
    riporter Member
    Charleston S.C.
    Whoa...is that sweeeeet or what!...some very nice work all the way around..particularly on the cage...I've got to do the same on mine at some point.
    Some excellent flow numbers on those heads also...2.15 intake valve?
    The block looks vaguely familiar...dont ya luv the meat in that thing?
    Are you able to get the flow numbers out of the BG 4150 style carb you need?
    I was happy when we found out we could get the required 1030 cfm on mine...I hate the look of a dominator on a small block:16suspect
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Yes sir, Sweet! What for block you have on that an cubes? Can't wait to see the numbers on yours running!!
  5. CometGT1974
    Western NC
    74 Comet GT
    They are 2.15 Xceldyne Titanium intake valves and 1.625 Ferrea Inconel exhaust valves. Yes, I do love the block!! I put the largest sleeves available in the race demon, I think they are like 1050 cfm are there abouts. I also have a dominator carb/intake combo that I will run in classes that allow it. I'm just kinda guessing at what it will do (since i've never had a motor like this) but I think that with traction 5.50's are well within reach, @ 2900 lbs.
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    All I can say is
    AWESOME!!!!!!!!
    :yahoo:
  7. CornedBeef4.6L
    no longer here
    I thought my heads flowed great 300 cfm@.500
    :biglaugh:
  8. CometGT1974
    Western NC
    74 Comet GT
    That's pretty good flow numbers at .500 lift, mine only flow 320 at .500 lift on a 4.125 bore.....a little bit more on my 4.155 bore but the head guy didn't have a 4.155 bore fixture.
  9. CornedBeef4.6L
    no longer here
    Having 2 intake and 2 exhaust valves doesn't hurt:)
    I'm just lacking about 150 plus ci:(
    4 valve cobra motors flow great factory . thrown in a CNC port job and they flow awesome.
    They are limited by the amount of lift though. You dont see to many cobra cams over .500 lift and even then the heads require machine work to get close to .500
    I am also inspired to by you to maybe up the N20 a tad but and go two stages.....100 shot an then another 100 lets thinsg ease in a bit a little less destructive on the internals...
  10. CometGT1974
    Western NC
    74 Comet GT
    Two words, "Progressive Controller" !!:thumbs2:
  11. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    This is a awsome thread. Listening to the 3-4 of you is very informative.
    Ray- What size motor do you have. is it stroked or stock . great times and hope to see you in Joplin.
    Rick it is co nice to hear from you.hoping to have a few with you in Joplin and pic your brain for some info to get my car to the high 12s in the 1/4. 302- 9.5 comp, 230 at 50 and 512 liift. 600 double pumper with 72s in the fromt and 76 in the back, 380 rear-spooled, 2600 flashing convertor with ET drag radials. Running about a total of 32 degrees in the mech dizzy.
    Stephan you are missed also and I would love to see you, your hunny(my dancing partner haha) and the car again. have been following ypur build and its very impressive. I learnalot just by following you 3. TTFN for now CRAZY CANUCT:yahoo:
  12. rayzorsharp
    Daydreamer...I'm running a 347 with Trickflow heads. Wish I could make it this year but things have been too hectic at work. Hopefully things will be better next year and I'll see you guys.
  13. CornedBeef4.6L
    no longer here
    If all goes well I'll be finally lining up against you :thumbs2:next year as well
  14. rayzorsharp
    Looking forward to it! :chirp:
  15. daydreamer
    Oshawa, Ontario
    1972 Ford Maverick
    goinna miss you ray. Hopefully will be there next yr also.Where ever "there" is:hmmm:
