RC-107
Discussion in 'General Maverick/Comet' started by yellow75, Jan 25, 2017.
  1. 71gold
    I understand, remodeling can be a brain twister.
    I'm a K.I.S.S. person myself. sorry I couldn't keep up with you on some of the stuff you were explaining...:Handshake:
    groberts101 likes this.
  2. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Resurrecting an old thread because it seems appropriate. For those who have done it, I have a few questions:
    Is it miserable to cut the towers out if I don’t have a plasma? I saw on the RRS tutorial that they drilled out each spot weld. Is that the best way to go or just cutting where the tower starts to come out from the wall of the bay?
    Is it necessary to pull the steering column from inside the car?
    Do other brackets such as the factory sway bar need to be cut off?
    Thanks!
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    My tool of preference would be the angle grinder with a cutoff wheel. Next would be a spot weld cutter. I bought the one on the left and used it but it will wander and is fussy to use. My brother bought the one on the right from Summit, it is a good tool, works like a champ.
  4. 71gold
    mine were just cut where the tower starts to come out from the wall of the bay. that way the flange that was spot welded on was left to reinforce the opening. my filler panels are bolted on for ease of access to the starter/plugs
    mine was cut with a plasma cutter. you can see them in the second pic in post #4.
