Ready To Run Distributor
Discussion in 'Technical' started by Bioinfomatic, Jul 14, 2008.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I don't think Duraspark is bad, and I don't think HEI is bad either. They do the same thing, they do it well, and they've both proven reliable for decades.
    But I do agree the HEI is big. I don't know, it's kind of a tradeoff. With the HEI you get to remove a lot of wires, the remote coil, the ignition box, and clean things up, but at the price of a bigass distributor cap. If it's that offensive looking though, you can get smaller HEI distributor caps that allow for an external coil.
    I might do that eventually. Stages, like everything else. I do things as the time and money allow. The HEI solved my problem economically, does a great job and I can't imagine any stock system doing noticeably better. :2cents:
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    If you run a duraspark you'll have an external coil and external ignition box.
  3. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    But I already have a external msd coil & wires to use, I just wanted to find a cheaper way of constructing a "ready to run distributor".
  4. Andysutt
    Conway Arkansas
    1972 Comet GT
    You can use the coil and wires w/ the duraspark.....
    You don't have to have a factory replacement type coil for duraspark. The MSD wires and coil you have will work just fine.
    Just make sure you get the correct cap for your wires (big or small)
  5. Bryant
    i run the duraspark dizzy with a msd box. it works great. you can start with the duraspark box and later as your performace demands it you can get the msd box and not have to change the dizzy.
  6. 48fordnut
    48fordnut Member
    mid ga
    I made 645 hp on an eng dyno with a dura spark. the coil is where the spark comes from.
  7. bmcdaniel
    Yeah, but how much power did your engine make? :D
  8. 48fordnut
    48fordnut Member
    mid ga
    i left my self open . thanks for the reminder:tiphat:.:)
  9. baddad457
    You can't beat a parts house reman Duraspark then..........$55 with a core to exchange. :thumbs2:
