Rear axle question- Dana 44
Discussion in 'General Maverick/Comet' started by Ford Freak, Nov 17, 2017.
  1. Ford Freak
    Ford Freak IG page the_marvelousmaverick -- follow me !
    United States, CALIFORNIA
    1972 maverick 2dr 200,c4 ,ac -sold. 1972 Mexican Maverick 302 4 spd - parted out , 1970 maverick v8 swap. 63 Galaxie 500 2dr sedan , 1984 VW Rabbit GTI
    Hi guys , so I parted out the Mexican Maverick , and prepping the driveline , 302 , 4speed , driveshaft,& dana 44 rear end.
    I was told that the dana 44 rear end is weak, u joints, spider ,carrier ... if it’s true it puts a dent in the budget for my 70 Mav .
    Just curious on what you guys know . Before I proceed to transfer the parts over .
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Weak is a relative term, any component can be taxed beyond it's capability. You real concern should be if it is adequate for what you want to do with it. How much power are you going to be trying to apply to the ground with this rear end?
    Ford Freak likes this.
  3. Ford Freak
    As of right now just a 302 , that will be stroked to a 347, If things go as planned a blower and aluminum heads an other bits needed to keep it together & done right
