Rear axle u-bolt?
Discussion in 'Technical' started by Russ, Apr 18, 2005.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Ordering my new springs tomarrow. I measured the u-bolts. Here's what I came up with. 2 3/4" inside (dia of axel tube) 5 3/4" long(from end of threads to inside of the U. 7/16" dia. fine thread. I have about 5/8" thread sticking out of the bottom of the nuts on the u-bolts. That should still be long enough to add a leaf right? I have 3 leaves now, going to order the 4 leaves. Do all of these numbers sound right? Thanks. Russ
  2. Craig Selvey
    I just ordered U-Bolts from Espo springs along with my leaf springs. What they sent worked just fine for the 4-leafs.
  3. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Well I had my wife TRY to order them for me today, and they told her that they only had specs. up to 73(mine's a 74) for the U-bolts I can't see where there would be any differance from 71 to 77 but I went out and measured just to be sure. I guess I should have called my self. Craig, how long did it take you to recieve you order after you placed it? Thanks Russ
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Ordered my U-bolts from ESPO as well. They already know which ones you need. Just tell them it's for a Maverick. They are the exact same size as the originals. There's no difference from '71-'77...
  5. Craig Selvey
    Seemed to arrive pretty quick.
  6. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    I just replaced my 7.5 4 lug with at 8" 5 lug out of a 74 maverick. Same size U-bolts and everything. I wanted new ones in a hurry tho so I went to all parts stores. after getting told they don't have them i found a older guy and he looked them up and found 2 that they had in stock.
  7. 71gold
    russ,
    we have a place in town that makes u-bolts...they take a straight rod that is threaded on both ends and bend it to what ever size you want...i was checking out my options when i did my 4 leaf swap... found out the stock bolts would work...frank...:bouncy:
  8. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Thanks for the replies. I had my wife call them today with the measurements I gave her. They said I could get everything in 7 to 10 days :)
  9. T.L.
    T.L. Banned
    Southern Colorado
    That's cool that you found what you need, but you really shouldn't have to provide measurments...
  10. bmcdaniel
    bmcdaniel Senile Member
    When I got my u-bolts from Espo they were slightly smaller in diameter than the originals. I even told them on the phone exactly what I needed. Anyone else have that problem?
  11. Craig Selvey
    I had no problems.
  12. T.L.
    T.L. Banned
    Southern Colorado
    No problems here either. I got exactly what I needed...
  13. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Well the UPS man dropped my springs off at 4pm today and by 8 pm I had them in the car.:jack: I still need to finish tightening a few of the bolts but they are where they need to be. So what is the torque specs. for the U-bolts and the front spring eye bolt? Hopefully by noon tomarrow it will be back on four wheels. :woohoo1: Then Sunday it going to snow. FIGURES:banghead:
  14. Craig Selvey
    Russ
    Please give us a full report as to:
    Where you got the springs
    How many leafs
    How it sits once installed, stance, rake, etc.
    Pictures too please!!
    I am needing new springs on the 74, .....and I need to know what others have used. Sure...I have new springs on the 72....but it is hard to tell anything since the car is still stripped.
  15. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    I bought 4 leafs from ESPO. I placed the order on Tuesday, and they were on my deck Friday afternoon.:clap: I started Friday around 5 pm and they were installed finger tight at 8 pm. I finished tightening everything this morning. Took it for a ride and it made a big improvement over the worn out 3 leafs(I used 4 leafs). I am disapointed in the ride height though.:cry: It may have raised the rear of the car 1". I was hopeing to get at least 2" of lift going with the 4 leafs.:huh: I didn't take any floor to wheel well measurements before I started, but I put a 2' level on the body trim on the door before I started, and I had to raise tail the end of it 1/2" to get the level to read level. After installing the springs, I still need to raise the back of the level 1/4" to make it read level. So it still sits alittle nose high. :mad: Over all I'm happy with the service from ESPO, but I guess I sould have asked to have the springs bent with a little more lift. O'well c'est la vie Russ
