Rear Brake Axle Block
Discussion in 'General Maverick/Comet' started by Renton5, May 15, 2021.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hi Everyone!
    I have a '71 Mav, 200 engine. I'm replacing/cleaning the entire brake system, except for the steel lines. Some years ago, when I was thinking about doing the brakes, I bought Dorman brake hoses with steel connectors. I finally cleaned the axle block (with the vent tube), seeing that it's brass. Should I be using a brass unit, or is the steel alright to use?
    Thank you!
  2. yellow75
    Tillamook Oregon
    Steel is fine that is what they have anyways
    RMiller likes this.
  3. Krazy Comet
    Dismal Swamp
    I don't remember seeing original distribution block that wasn't brass..
  4. yellow75
    Tillamook Oregon
    Maybe a little confusion here, yes for brake lines with steel fittings on brass distribution block
