rear brake lines
Discussion in 'Technical' started by Racer_X, Dec 17, 2012.
  1. rickm
    rickm Member
    Owosso Mi
    I've used the copper stuff an I think it bends easy. I used it by the MC and the prop valve. On the axle I would go with the prebend for the perfect fit.
  2. rthomas771
    THIS IS NOT SAFE...Copper is too soft...it will split open under the high pressure used in the brake system. Using copper fitting is a no no also. The pressure will wipe the threads off the fitting
  3. rickm
    rickm Member
    Owosso Mi
    It's copper and nickel, it's used by Audi,and alot of others. I think if it wasn't safe they sure wouldn't be selling it for brake lines !
  4. tody
    tody Member
    cologne, germany
    the NiCopp stuff from jegs is what i used, too. it's an alloy with copper, nickel and iron. the name used over here is CuNiFer, derived from the chemical symbols for the three metals.
    it's easy to bend by hand, and easy to make flares.
    on my 4-lug mav rear, i used the pre-bent 65/66 mustang brake lines, which were an okay fit - but i used a 65 mustang rear brake hose, too.
    BUT what has to be considered is the position of the axle vent tube. it would be a waste of money to use mustang lines, just to find that they are made for an axle housing with a differently positioned vent tube.
    if i would use pre bnt stuff on a mav, i'd probably go with Right Stuff Detailing mentioned above!
  5. Dave B
    Audi stuff on a Maverick!!! Shame on you!!! :D
  6. 71gold
    or was it the ...copper, nickel and iron...
    ...:huh:
  7. rthomas771
    You didn't say "copper/nickel"…you said “copper stuff”. Big difference between the two. Your post sounded like you went to Home Depot and bought a roll of copper tubing. I'm sure the original poster could have thought the same.
  8. Acornridgeman
    Wisconsin
  9. Joe Dirt
  10. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    when it come to hoses and lines i buy more than what i think i will need just in case plus me or my dad may need some later on, i can use the extra on my other project if i need to, or pops can use some for his three projects. nothing goes to waste in the garage lol.
  11. rthomas771
    As long as you know you're gonna use it then buy what you want :Handshake
  12. rickm
    rickm Member
    Owosso Mi
    OK my error when I said copper and didn't add the nickel. I know copper won't hold 3k psi. But hey if you get the good compression fittings:rofl2:
  13. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    copper
    I offered to help an elderly friend When he told me that a line broke on his 1929 Rolls Royce. When he showed me a roll of refrigeration tubing, I told him you cant use that! He said why not ( He was an combustion engineer from TRW) thats whats on the car! Needless to say we replaced the copper brake line with another.........All the lines were copper! The Secret he said is you MUST anneal( softening by very controlled heating) the tube before flaring or it will split. He did that with a propane torch and it worked as he said. I Have never used copper before or since for brake lines. I always thought the same thing copper wont hold the pressure! 1/4 Refrigeration tubing is rated for 980 PSI. 1/8 Refrigeration tube (1/4 Outside Diameter) is rated for 1400 PSI. Fittings is were it normally fails, most connections on refrigeration equipment is soldered.
  14. 71gold
    enough said...:D
  15. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    copper
    Well actually copper was used as brake line on most early cars and even chrysler into the late 30's, MG's late 40's....AACA judges deduct points for not having the correct material brake lines.
