Rear diff oil change
Discussion in 'Transmissions' started by Warp9, Apr 5, 2019.
  1. Warp9
    Warp9 Member
    Simcoe Ontario Canada
    1972 Ford Maverick Grabber
    I know it's not a trany question, but it's still the drive line and I'm not sure how to proceed so I hope someone can give me direction. I want to change the oil in my rear diff . It's a 2.73 with a solid (no bolted cover) back end. What is the best way to get the old oil out. New stuff is easy, in the fill hole.
    Thanks
  2. 71gold
    may take a few minutes but you could double nut a couple of the bottom case studs and back them out. take the filler plug loose so it can breath...:huh:
  3. Krazy Comet
    Assuming the vent line isn't plugged, it will breath.
  4. Warp9
    Warp9 Member
    Thanks, I will give it a try
