Rear Diff
Discussion in 'Technical' started by Maverick_Ian90, May 21, 2019.
  1. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    So my car is currently a one-legger. Obviously want a limited slip for more...umm....traction. Is it better to get a new carrier or should I cheap out and get a mini-spool? Rear is 8", by the way.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If you drive on the street, don't run a spool.
    jasonwthompson likes this.
  3. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  4. Maverick_Ian90
    Northeast
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No. An 8.8" is an 8.8". It's a C-clip axle rearend like the older GMs.
    mojo and Krazy Comet like this.
  6. Krazy Comet
    A 8" & 8.8'' are about as different as two rear ends can be. From the late '60s, Ford has used 6 7/8", 7 1/2", 8", 8.5" 8.7", 8.8', 9" & 9 3/8". This last one is a 9" carrier with larger gear. Same for 8.7" vs 8.5". Plus there were other mfgr rear in HD trucks.
  7. mojo
    If you don't have some good fabrication skills --- work w/ your 8". If not running big power, manual trans leaving line 5K+ rpm, stick tires - the 8" will serve your purpose.
    Hotrock, 71gold and Shorty like this.
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Skip the mini spool and get a proper differential.
    Maverick_Ian90 likes this.
  9. 71gold
    if not on sticky tires, get a locker and some 3:55 gears for that 8in.
  10. Maverick_Ian90
    Northeast
    Any recommendations?
  11. 71gold
    this is the one I ran in my 8" with 3:55 gears behind my 347 ci.
    Eaton Detroit Lockers 68289
