Rear disc brake conversion question...
Discussion in 'Technical' started by mrcomet, Mar 18, 2009.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Thanks for the info!
    I've heard that you can pop out the residual valve on the old master cylinder and that would solve the problem (no need for a new 4-wheel disc master cylinder). Any thoughts????
  2. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    Hmm..now that you mention it, I think I've heard that too. I just don't know how to do it...maybe it's threaded into the master cylinder?
    I'd say it's worth a shot! :)
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I believe you can use a sheet metal screw and thread it into the residual valve to pull it from the master cylinder port.
  4. Mavman72
    If you pop the RPV you will still have a M/C with inadequate capacity to feed disc brake calipers properly....
  5. Bryant
    you can get a m/c for a 86 svo mustang. (turbo 4cyl). they have 4 wheel disks and the m/c is aluminum.
  6. curtisc
    curtisc Member
    Moscow...... Ks
    1978 F-150, 1971 Maverick, 79 Bronco
    I found the other posts, they mention no need for compensating the residual pressure issue...
    http://mmb.maverick.to/showpost.php?p=169995&postcount=15 (mavman)
    http://mmb.maverick.to/showpost.php?p=134910&postcount=12 (Old Guy)
    http://mmb.maverick.to/showpost.php?p=417380&postcount=1 (eddie Maverick)
    IF... the dodge unit is the same has the wilwood unit (260-4894) then dodge put an inline 10lb residual pressure valve. I say 'if' only because i can't find a spec sheet for the dodge unit, but the wilwood is HERE and they look identical and all of the dimensions are the same.
  7. Bryant
    i belive that the residual pressure valve is in the porptioniing valve in a lot of brake systems.
