Rear end damage
Discussion in 'Maverick/Comet Projects' started by stoney, Sep 2, 2015.
  1. Craig Selvey
    What do both quarters look like? What about the floorboards, torque boxes, etc?
  2. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    Back floor board under seat look good, have not pulled carpet yet. It's been a while since I've been under car, don't know what it looks like at present.
  3. Craig Selvey
    I would say, after looking at all the pictures, you really need to replace the entire passenger rear quarter panel.
  4. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    I'm trying to figure how the tail panel attach to the body and can it be replaced
  5. Craig Selvey
    It is welded on. You will need to drill out the spot welds.
  6. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    I went out this morning and lookedat it i saw the welds, i now have a better understanding how it all goes t together, thanks
  7. Mavman72
    You need to get under that car and see what you have. Look at torque boxes/frame rails (Rears like to rot at the leaf spring shackle mount) Check the cowl for leaks...I would start looking for a pair of quarters and a tail light panel...
  8. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    Like most parts on the Mavericks, is the tail panel common and hard to come by
  9. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    Would a 4dr tail panel work, what could I use from a 4dr?
  10. Mavman72
    A 4 door panel will work but...The tops of the quarters/decklid edge are shaped a bit differently. It really wont matter though. Its not unusual to see rotted tail panels but they usually survive tin worm. Thats why I stated that you need to go over the whole car first...If the tail panel is rotten, the trunk floor usually is too. Rotten tail panels are usually found on really rotten (over all) cars.
  11. Mavman72
    You could use the lower rear quarter panels, trunk floor, front floor pans, cowl panel, 'A' pillars( front door posts) windshield, front clip in its entirety.Thats aprons/rails as well as body panels. Front ans rear bumpers. All drive train components minus the drive shaft( its a bit longer) etc...
  12. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    The panel is not rotten,just damaged on one side. The floors are good,as is the trunk
  13. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    Would you have rear tail light panel
  14. yellow75
    Tillamook Oregon
    Yes, but there are probably people closer that would have one, shipping items the size that you need are costly from the west coast to you, just trying to save you money but I will send you any panels you need.
    I suspect you will need a passenger rear quarter section with the drop down for the trunk area and some of the tail light panel and some wheel well patch pieces
  15. stoney
    stoney Member
    simpsonville sc
    72 Sprint, 302
    Drop down for trunk, is that the corners at the 25 extension
