Rear panel plaque
Discussion in 'Cosmetic' started by leeinphx, Oct 9, 2017.
  1. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    How unusual is this plaque behind the tail lights across the back of my '75 LDO? I love this look. I will need to repaint, so does this come off easily so that it isn't damaged?
  2. Doug
    Doug Member
    washington state
    71 maverick grabber
    I would worry as old as the material is it would rip . I would remove the chrome and paint around it . After you remove the chrome it amy just fall off . Just my 2 cents
  3. Craig Selvey
    It’s glued on, so if it not loose....leave it. The trim bolts on inside the trunk.
  4. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Thanks, a good masking job in store for that.
  5. 71gold
    replace it with a new piece of vinyl top material (your choice of textures)...use the trim or old piece for a template...:thumbs2:
    anyone wanting to add this to their car could get the trim and do the same thing.
