Rear passenger brake light not lighting when brake is pushed, please help!!!
Discussion in 'Technical' started by double0beaver, Aug 30, 2015.
  1. double0beaver
    double0beaver Member
    California
    1974 ford maverick
    Hello, my Mav is 74, 250 i6. My problem is when I step on my brake pedal, my rear PASSENGER tail light does not illuminate BRIGHTER. ( if I turn my head lights on, it will light up, but still will not brighten to warn other drivers as I'm stepping on the brakes) Driver side works fine, ( will light up, and dim when I release the brake pedal) so far I replaced the bulb, socket and brake light switch, passenger turn indicator is also not working.... Any suggestions? Thanks fellas...
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The bulb needs replaced.
    double0beaver likes this.
  3. double0beaver
    California
    1974 ford maverick
    When I swap the passenger bulb with the Driverside bulb, which is working fine, I still have the same problem on the passenger side only...
  4. mojo
    Check the socket for corrision, check the ground/clean both as necessary.
    Crazy Larry and double0beaver like this.
  5. double0beaver
    California
    1974 ford maverick
    New socket, good ground, thanks for the input, checked these tho...
  6. 71Mavrk
    71Mavrk Member
    Nevada
    Check continuity between the driver brake light and the passenger brake light. Might be a broken wire.
    Micah
    71gold and double0beaver like this.
  7. Krazy Comet
    Dismal Swamp
    With brake applied or signal on, check for power on the orange & blue wire at the signal sw plug where it exits from column... No power indicate a signal sw problem...
    double0beaver and Craig Selvey like this.
  8. 71gold
    I'll go with this also...:yup:
  9. Craig Selvey
    Broken turn signal switches do strange things.
    double0beaver and Krazy Comet like this.
  10. Krazy Comet
    Dismal Swamp
    Could be a broken wire between column and lamp socket but continuity from one side to other is through the signal switch... Can't have a common feed between the two or both R&L lights would blink when either was selected...
  11. double0beaver
    California
    1974 ford maverick
    Thanks for the input gentlemen! I will b checking these this evening hopefully , busy day today!
  12. 71Mavrk
    71Mavrk Member
    Nevada
    Tom,
    Your right. Must have had my head up my ... when I wrote that one.
  13. Krazy Comet
    Dismal Swamp
    It's already been stated socket is new...
    Here's the internal circuit of the signal switch...
    double0beaver and Maverick Dude like this.
  14. Krazy Comet
    Dismal Swamp
    You could be correct, but if symptom is same after replacement, that puts serious doubt that either socket is/was causing problem...
  15. double0beaver
    California
    1974 ford maverick
    All good information guys, very much appreciated. Diagrams will help much as well. Checking into all of this fun stuff tomorrow. If all else is good, and according to the wiring diagrams, I am starting to think turn signal switch is the culprit .... I will check it 1st. also, the socket is good:)
