Rear Shocks
Discussion in 'Technical' started by markso125, Oct 1, 2011.
  1. Mavman72
    Me too...:bouncy:
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Anybody install a set of these KG5447 yet? I need to change out my rear shocks cause the bushings are coming apart. And I have KYB Gas A Just in the front. Ill need to get a set of these for the back.
    Thanks for the research Markso125
  3. tody
    tody Member
    cologne, germany
    will do it this weekend
  4. hyperballsmcgee
    hyperballsmcgee Member
    Murfreesboro, TN
    1974 Maverick 2 door
    I run Gabriel Hi-Jackers in the back. they're gas shocks, and i keep 'em blown all the way up, yet they still give a really smooth ride. only time it's rough is if i back out of a steep drive way or something similar.
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Those are the dreaded "Air shocks"..they are not reccomended to run on our cars(especially blown all the way up) because they have a tendency to destroy the upper sheetmetal shock mounts, especially when they have no give in them because they are fully pressurised.
    The sheetmetal shock mounts fail before the shocks give and end up ripping a hole in your trunk floor.
    The KYB shocks we are talking about are performance monotube shocks, they are more performance oriented and wont jack up the car or make up for failed spring rate.
  6. tody
    tody Member
    cologne, germany
    i finally put these shocks in today.
    no drive experience, though - engine is scheduled for rebuild.
    pictures of the rear stance tomorrow - front wheels still off due to shelby drop.
    two things i noticed:
    these shocks do not come with the upper bolt. i took it out of my old kyb gr-2, fit perfectly.
    i believe the one inch difference in length is immediately noticeable. with the old gr-2, i actually had to push the rear axle UP to get the lower nuts on the shocks. with the new shocks, i had to compress them to get them in. that is with one year old jrs 4 leaf springs.
  7. vvr210
    vvr210 Member
    Vista,CA
    Has anyone installed these and tested them yet?
  8. Blue Brick
    Blue Brick Member
    Very Nice!!!!
    81097 Guardian Shock
    Detailed Specifications
    Specifications
    Product Line: Guardian Shock
    Shock Extended Length: 18.2 in. 462.28 mm.
    Shock Collapsed Length: 11.09 in. 281.69 mm.
    Length of Stroke: 7.11 in 180.59 mm.
    Accessory Kits: 140524
    Upper Mount Code: EB1
    Lower Mount Code: S1
    Where Used
    Loc. Year Make Model Vehicle Attributes Application Notes
    R 69-72 Nissan 521 Pickup
    R 75-79 Nissan 620
    R 72-74 Nissan 620 Pickup
    R 80-81 Nissan 720
    R 82-85 Nissan 720 RWD
    R 86 Nissan 720 RWD Mfg. to 8/86
    I also found this, but it requires a sleeve for the ½ inch mounting bolt.
    81338 Guardian Shock
    Shock Extended Length: 17.95 in. 455.93 mm.
    Length of Stroke: 6.86 in 174.24 mm.
    Accessory Kits: 140873
    Upper Mount Code: ES27
    Lower Mount Code: S14
    Where Used
    R 77-83 Chrysler Cordoba
    R 83-89 Chrysler Fifth Avenue
    R 81-83 Chrysler Imperial
    R 77-80 Chrysler LeBaron
    R 81 Chrysler LeBaron M Body
    R 79-82 Chrysler New Yorker
    R 79-81 Chrysler Newport
    R 79-81 Chrysler Town & Country
    R 76-80 Dodge Aspen
    R 77-78 Dodge Charger
    R 77-89 Dodge Diplomat
    R 78-79 Dodge Magnum
    R 80-83 Dodge Mirada
    R 77-78 Dodge Monaco
    R 79-81 Dodge St. Regis
    R 88-89 Plymouth Caravelle RWD
    R 78-81 Plymouth Caravelle RWD
    R 77-78 Plymouth Fury
    R 80-89 Plymouth Gran Fury
    R 76-80 Plymouth Volare
  9. Mavaholic
  10. Don Check
    Don Check Member
    Allen Park, Mi. 48101
    1972, 74 mavericks
    Hum, I got some of these rear shocks coming, going to try them out. They will replace a plain old stock shock. I just installed some Cal Trac's also. Also the one member is right about air shocks, DON'T USE THEM ON MAVERICKS! My one friend did and it eventually poked a hole right through the trunk!
  11. Don Check
    Don Check Member
    1972, 74 mavericks
    I installed the KYB rear shocks on my 74 maverick (part #kg5447) a couple days ago. They fit perfect, the only thing you have to do is use the maverick upper mounting bolt setup and remove the steel sleeve from your old shocks upper rubber and insert them into the top rubber ends of new shock and bolt them on. This way when you tighten them down on top, the sleeve won't allow the rubber to be crushed, just like stock setup. I also used the lower mounting rubber and washers from old shocks because they are bigger, the ones in the kit looks like they will work but a smaller. I noticed the shocks are way more firm then what I had on it, took car for a ride and they work perfect.
  12. 71gold
  13. Don Check
    Don Check Member
    1972, 74 mavericks
    Good artical on springs & shocks! There is no performance shock available for the rears of our cars, the KYB shock thats actually for a Nissian truck looks like a stock maverick, works just fine and it is a monotube design. Now if you want to change everything from stock, there are other ways to do a drag car setup.
  14. 71gold
    Don, surly you have more than one friend...:cry:
  15. Don Check
    Don Check Member
    1972, 74 mavericks
    Well, the way they are all dropping (friends), might end up getting down to one LOL!
