rear springs
Discussion in 'Technical' started by macinamav, Oct 6, 2006.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    JC Whitney has free shipping on purchases over $75 though 10/20/06, use code SETHK06
  2. Jamie Miles
    Alto, GA
    I've had a few
    Great info, so where do you guys suggest purchaseing new shackles and bushings?
  3. Acornridgeman
    Wisconsin
    AK or ESPO - you can also buy Mustang ones and change the larger bushing over to a Moog, part # K8785
  4. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Will the JCW Springs correct a sagging rear car to an even stance?
  5. scooper77515
    They "should" assuming that the springs are the cause of your sag. I thought mine was, replaced all the springs and shackles and bushings, and still had a 3/4" sag to the driver side. I now assume that a couple of those fender benders my great-grandmother had in the car bent the frame a little.
    If your frame is straight, the new springs etc should settle it out.
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    You can clean and reuse your original shackles as long as they are not rusted or bent. That's what I did. Bead-blasted & repainted 'em. I replaced the U-bolts with new ones...
  7. scooper77515
    I only bought new ones because I threw away the originals when I put on the longer shackles :slap:
  8. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Mac, the roof looks good is this the same car the guy was walking on the roof?
  9. Maverick73
    Lakeland, FL
    I think I heard that the ESPO springs will raise the rear about 2 inches correct me if im wrong. Does that look better having the ESPO springs vs the JCW springs?
    Also, is there any quality difference between the ESPO, JCW or other springs?
  10. Maverick73
    Lakeland, FL
  11. macinamav
    macinamav Sr. Junior Member
    Anchorage, Alaska
    1970 Mav
    Springs
    TY WARD still have a few freedoms left up here but rapidly disappearing like lower 48 Don't want to compete too much with Feds:yup:
  12. macinamav
    Anchorage, Alaska
    1970 Mav
    yes Russ it is the same one.......... many sheets of 320 grit later lol
  13. Jamie Miles
    Alto, GA
    I've had a few
    Walking on the roof huh? Sounds about like what I have to deal with on my '69 1/2, except I think someone was jumping up and down on my roof. :(
  14. Maverickgrrl
    Maverickgrrl Member
    Des Moines, Washington
    Does anyone still use http://www.autokrafters.com/ ? They still have the Mav catalouge...
    PS - go for four leaf - the only way to kill SFA (Saggy Ford Ass)
  15. T.L.
    T.L. Banned
    Southern Colorado
    Dang Paulie, I didn't know that was you!....
