Rear Suspension Upgrades
Discussion in 'Technical' started by Cloontang, Apr 9, 2020.
  1. Cloontang
    Cloontang Member
    Chandler Arizona
    1974 Comet GT
    Finally got the 347 up and running in the Comet, next step is the saggy rear suspension. I am also ordering subframe connectors from chassis engineering. I've been looking through old threads and couldn't seem to find a definitive answer on leaf springs (3 vs 4 and spring rates), I'm also wondering whether or not the difference between single and double adjustable shocks justifies the price? The car will be mostly street driven with some auto x in the future.
  2. Krazy Comet
    For '70-'72, here's what Ford Master Parts Cat says. Code 54 is for 4 dr & 62 2dr.
    Rasit, HadaGrabberonce and Cloontang like this.
  3. TeeEl
    TeeEl Senior Member
    Colorado
    You'll get different opinions. I've replaced leafsprings 3 times in my '73. First time was 4-leaf from JC Whitney. Decided they were too stiff. Replaced them with 3-leaf from ESPO. Car sat too high. Replaced again with 3-leaf (also from ESPO) with 1-inch drop. Still rides pretty stiff. I even got rid of the polyurethane bushings and installed new rubber. Shocks are KYB twin-tube...
    DRT and Cloontang like this.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    With stock leafs I installed polyurethane bushings and competition engineering slapper bars with air shocks my car went 1.48 60" very consistently.
    Cloontang likes this.
  5. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    I used 4 leafs which cured the sagging rear but as TeeEl stated, the ride is a little stiff. Not sure of the spring rate or even what brand they are. Bought them from the now defunct Laurel Mountain Mustang. Probably the same ones that J.C. Whitney carried. I am ok with the ride height now and even though the ride is a bit stiff, I like the handling improvement. Also added Addco rear sway bar with KYB shocks.
