Rear Sway Bar Question
Discussion in 'Technical' started by coreyjhen1, Mar 21, 2022.
  1. coreyjhen1
    coreyjhen1 Member
    Albuquerque
    Has anyone used the Scott Drake C5ZZ-5486-ADJ rear sway bar? If so, was it a reasonable installation?
  2. dyent
    dyent Member
    vancouver bc
  3. mojo
    Was there noticeable improvement in handling? Do you have frame connectors on the car?
  4. dyent
    dyent Member
    vancouver bc
    Hi Everett:
    Using a rear sway bar on "stock" rear leaf springs will definitely improve the handling, less roll and keeps the back end "flat". Once you beef up the rear leaf springs (increase the spring rate) or start playing around with lowering the height, rear sway bar may not be necessary, it all depends on what you have done or will do on the car. But this all goes hand in hand with better tires, shocks, larger front sway bar.........
    I did not have any frame connectors on my car at the time I had rear sway bar........take care!
    David
  5. Powerband
    Powerband Member
    NY's \H/
    Sway bar observations ... anecdotally :
    .. added Addco 5/8 " rear sway bar to my '63 Falcon Wagon (with frame connectors ) that has a 3/4" front sway bar which reduced understeer significantly.
    The added rear bar does seem to increase steering input reaction related to higher speeds..
    have fun
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Addco makes a Maverick and Granada rear bar, what's the difference? I thought the frames were the same on the two cars.
  7. 71Mavrk
    71Mavrk Member
    Nevada
    If you do it, remember, you need to add material to the frame rail or it will more than likely rip it out. I have the Addco upgraded front and the back.
    I have done a fair amount of suspension modification. Mine handles like a go-kart. Nice and flat in the corners.
    See pictures in my build.
    Micah
    Jaybee and mojo like this.
