Rear wheel stud help
Discussion in 'Technical' started by Bad Brad, Jul 5, 2015.
  1. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    The problem I'm having Larry is I can't find studs to try. The set from the parts store is $117 and I'm not paying that for studs! Lol. I have not found any aftermarket company that makes them in a knurl close to mine. If i could find a set of axles from an older or newer maverick, then I would be just fine. But the small knurl for the 74-75 cars is what's causing my headaches. I'll figure something out.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Here are some. They're 4 bucks-a-piece, so you're looking at $40 for the rears. Free shipping.
    http://www.cjponyparts.com/lug-stud-rear-extended-2-3-16-1965-1973/p/HW1176/
  3. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    There again, the mustang knurl size is .625. I appreciate the help Larry.
    Edit: Ok, so I found something that will work. Dorman part# is 610-298. Used on the ford econoline and some f250's. .547 knurl and 2 inches long. So that'll give me my 1/4" back anyways. Man, this hot rodding stuff us stressful!
  4. Craig Selvey
    I see them on eBay all the time.
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A stud for a '73 Mustang is no different from a stud on a '73 Maverick, unless perhaps it's for a 9-inch rearend, but many '73 Mustangs had 8-inch rearends.
  6. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    You are correct Larry, but the 74-75 is different. Mine is a lot smaller. .545. Earlier mavericks and the mustangs are .625
  7. Rasit
    Rasit Member
    SE Pennsylvania
  8. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    Yes Rasit, those are the stock studs. The ones I picked up are a .547 knurl and 2 inches long. Should work just fine.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    'Sorry, I forgot you were working on a '74.
    Bad Brad likes this.
  10. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    Yea, sorry for not putting it in my original post. Guess that might of been a key point. :)
