rebuild front end
Discussion in 'General Maverick/Comet' started by ricardogarces, Jan 24, 2015.
  1. ricardogarces
    ricardogarces Member
    nogales az
    1971 maverick
    hi guys, im rebuilding my front end right now so i need advise from the suspension gurus lol, im doing UCA,LCA all 4 ball joints, sway bar bushing and end links .but this is my concern upper control shaft seems ok should i replace them, i mean the shaft or you guys suggest the whole UCA?? can i just replace the UCA shaft or go with the moog problem solber now that i have them apart....sorry if i made mistake englisg is not my first language, im from mexico and my mav in mexican too with a danna 44 rear end
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Replace the UCA with the shaft . if you buy the complete assembly will be cheaper
  3. maverick@heart
    maverick@heart Member
    Hendersonville TN
    1975 American Maverick, 1976 Mexican Maverick, 1973 Maverick
    Yo lo cambiaria todo. De hecho yo consegui todas las partes en kit por 300/dolares. Es curioso el que yo tambien tengo un maverick mexicano y le voy a cambiar toda la suspension y direccion en unas semanas. Saludos.
  4. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Whadhesay?
    Richard Kuss likes this.
  5. Krazy Comet
    maverick@heart and Paul Masson like this.
  6. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I prefer moog over cheap parts.
  7. coutangman
    coutangman Member
    Charlotte, NC
    I just did the Comet GT with all Moog parts. Previously, I did the '73 Stang conv and the '69 XR7 conv with Moog also. Only way to go for the long run.
    Jim
    Paul Masson likes this.
  8. schroensr
    1975 Mercury Comet
    I totally agree.
  9. ricardogarces
    nogales az
    1971 maverick
    thanks guys! UCA are on its way, also all moog parts required. what can you guys tell me about poly bushings? i know its a no on the struts, but end links? lower control arm? sway bar? should i get them?
    gracias maverick hart , tomare en cuenta lo de los kits
  10. schroensr
    1975 Mercury Comet
    They give you more stability and control. Rubber bushings tend to flex an wear faster.
  11. Northern
    Northern Member
    '74 Maverick
    yep. LCA is right there...2 nuts and its off. Moog makes some. and as for the sway bar, I am shopping too and want to tag along for the responses.
  12. schroensr
    1975 Mercury Comet
    I put the addco sway bar on mine
  13. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Jim:
    Did Kim's Maverick also with same and the ADDCO 7/8" ths Sway Bar. Should have the car off jack stands today .. then it's off to the alignment shop with a flat-bed tow truck . I want the alignment right-on before driving any distance. Will you make it to the NPD All Ford Show next year ? If so , we' ll see you there.
    Cometized
    (Chip)
  14. schroensr
    1975 Mercury Comet
    I am not sure , never purchased from Kims Maverick. Where are they located.
  15. William623
    Orlando
    1973 ford maverick grabber
    He meant his daughter's (Kim) maverick.
