Rebuild my FMX to 351w?
Discussion in 'Transmissions' started by lilacso, Mar 25, 2013.
  1. lilacso
    lilacso Member
    Walden, NY
    1976 Maverick
    So I need to have the FMX rebuilt... When I first bought the car and had it checked out I was told the tranny didn't have much life left. I do not do this work myself so I have to rely on what the mechanics say. I was contemplating swapping it out for a c4 or c6 but was told the FMX was the only thing compatible (or that just plain made sense) for the 351w motor in it. I have a pro-matic shifter in it that I have had to replace the cable for. I was told there was a shift kit in it but I'm not sure. It always gets stuck in gears... mainly starting and staying in 2nd. Will a rebuild solve all of my shifting problems? Will a new shift kit enable me to use the ratchet shifter without tearing up the tranny?
  2. Krazy Comet
    Ditch that hog, save at least 40Lb and get a C4, there no reason one can't be used...
    Almost no one runs a FMX these days...
  3. fourbrrl
    fourbrrl Member
    Shepherdsville KY
    71 Grabber 357 inch 392 HP windsor
    I'll second Krazy Comet........get the TCI s streetfighter and s streetfighter converter..stick with the small bellhousing and 157 tooth FW...takes up less room for header clearance
